Old 03-11-2016, 09:03 AM
k3r3n3 k3r3n3 is offline
Default Xpand2 Pro Tools 12.4 Problem
Xpand2 and other Air Instruments Bundle Version 12 suddenly stops playing sound . It loads fine but when I hit the keyboard (M-audio Axiom Air 61) then it stops sounding. Other instruments viz...Ezdrummer , Kontakt , Reason etc. working fine.
Need help ASAP....plz
Old 03-26-2016, 10:41 PM
Default Xpand2 missing sound in Pro Tools 12.4
Any ideas why I can't get Xpand!2 to sound when playing a MIDI keyboard direct onto a MIDI track? I am using Pro Tools 12.4.0, I have done everything that I am supposed to regarding arming the track, activating monitoring etc. The track shows it is getting MIDI signal and other plugins sound. The plugin works fine on previously recorded MIDI on Pro Tools . Just not as a live plugin on Pro Tools
Old 03-27-2016, 10:25 PM
Default Re: Pro Tools 12 - Register, Download, Install, Activate (Video)
Old 03-28-2016, 09:16 AM
digi98 digi98 is offline
Is it a MIDI track or an Instrument track? Other plugins in same track? Is midi channel set properly ?
Old 03-28-2016, 10:19 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Re: Xpand2 Pro Tools 12.4 Problem
Well, you're not giving us much to go on, so not sure how to help.
Create an instrument track. Instantiate Xpand on it. Record arm it. Call up a sound. Play the controller.
If you're MIDI studio is set up right to recognize your controller input, then you should hear Xpand2 playing.
If there are MIDI notes on the track, will it play those, but NOT when the controller is played?
Do you have a MIDI signal from the Controller getting into PT? (create a MIDI track, record arm, select your controller as the MIDI input to the track, and see if MIDI signal is there. If not...that's an issue with your MIDI set up).
Make sure the OUTPUT for the Instrument track has Xpand2 listed and it isn't greyed out or some other VI listed there.
Hope that helps.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Dell XPS 435T/9000 Win-10 Pro 24gig RAM
IntelCore i7 CPU 920@2.67GHz
Pro Tools 2018.12
Focusrite Scarlett 8i6
Old 03-30-2016, 06:11 AM
So sorry for delay...
Yes I am getting midi signal in my DAW , I/O , midi controller ....everywhere, but the problem is when I open my DAW for the first time it works (Xpand2)suddenly after some time sound gets missing. In the same time others instruments works fine. Only the AIR INSTRUMENTS BUNDLE giving problem.
Old 03-30-2016, 04:27 PM
There is nothing specific you do that kills xpand2? You're saying it's totally random when it chooses to stop after working fine?
Old 03-31-2016, 12:23 AM
then....no solution at all ???
Old 03-31-2016, 11:24 AM
audioman1973 audioman1973 is offline
I'm assuming that you do have midi thru selected in the options drop down menu?
Pro Tools HD 12.7.1, 3 X UA Apollo 8p TB and Octo Core card with UAD Plugins. Various Avid Sonnox Flux Drumagog and Plugin Alliance plugins. Motu MIDI Express 128, Windows 10 Pro, Gigabyte Z170X-UD5 TH motherboard, 64 GB Corsair Vengeance DDR4, Intel i7 6700k, Samsung 950 M2 OS drive and 2 X Samsung SSD plus spinner drives
Old 04-01-2016, 06:10 PM
LightWing's Avatar
LightWing LightWing is offline
Had the same issue with an Axiom 49 a few months ago. Turned out the controller was going bad (had it for 7 years). Picked up a Nektar controller for my basic use of the AIR Plugins and it worked right out of the box under Win 7 Pro SP1.
Patrick
www.LightWingStudios.com
Musical Instrument Protection Accessories...Made In America.
KeyShield HD, AxeShield HD, AxeSak, AxeGlove & AxeCap
Win 10 Pro, PT 12.8.10 Native, Dell Precision T5500, Dual Processors (12 Cores), 72GB RAM, 5@500GB SSD, 1@4TB HD, Nvidia 2GB HDMI Card, Vizio 39" TV as Monitor, Presonus AudioBox USB Interface, Mackie HR-828 Monitors, Katana Head, Fishman Triple Play, AIR Music & East West Plugins, 9 Guitars...& an AMAZING wife. :)
xpand2 problem oplatner Pro Tools Software (Win) 5 07-26-2016 06:33 AM
xpand2 problem secret_sound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-10-2012 09:04 PM
Problem with Xpand2 Titans55 Virtual Instruments 0 11-09-2010 08:17 PM
Xpand2 Problem MrSlaps668 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 10-11-2010 10:04 AM
MIDI, Xpand2 problem Falcon491 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-22-2009 08:42 AM
