Old 01-26-2016, 01:26 PM
benwahguitar benwahguitar is offline
Default Recording Delay with External MIDI Devices
Hi there. I know this topic has been covered many times but I still can't seem to get this working in my setup despite following the advice on other threads. If anyone has a simple explanation it would be much appreciated. I'm sending a MIDI performance from a MIDI track in Protools to my Novation Bass station II Hardware synth. When I record the Audio on a seperate track it is delayed. I.e The wave form comes in slightly after the downbeat even though the MIDI file is quantised. Is there a way to get a round this? Many thanks.
Old 01-26-2016, 02:20 PM
Default Re: Recording Delay with External MIDI Devices
Consider a few details here;
#1-midi latency can be anywhere up to about 10ms
#2-audio input will have a modest amount of latency(the average converter latency is half to 3/4 of a ms)
#3-whatever buffer setting you use will add latency(smaller buffer=less, higher buffer=more)
Since you are recording back into your session, its pretty quick and easy to use Tab to Transient to locate the initial note>separate at that point and nudge so it aligns with the first midi note and you're done Alternatively, you can set a midi offset amount to compensate
Old 01-26-2016, 11:53 PM
Thanks for the reply! Great this is a huge help.
PT 8.0.5 LE and Midi external devices problems paul_pogba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-13-2015 06:05 AM
Help Needed with Midi / External Devices Dingo8UrBaby Pro Tools 10 2 07-14-2015 05:40 AM
Problems with external MIDI devices and Pro Tools 8 Lac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-08-2011 09:44 AM
Help: PT's MIDI Clock doubles external devices' BPM msb212 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-03-2008 05:38 PM
Time delay problems using external effects devices... popps 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-07-2001 12:59 AM
