Old 10-04-2015, 05:50 AM
jkeefauver jkeefauver is offline
Default PT 12 Track Presets
This isn't new, been around for some time but I'm just getting around to implementing it. Figured I would reiterate the steps for anyone in the same boat. If you don't understand what this is about, search up a video on PT track presets and it will all become apparent. Anyhow, here's how I did it in 12 and I'm sure it works this way in 11 as well. 10 and before have different instructions but I'm sure they are pretty easy to find.
SOLVED: The actual track presets have to be in subfolders under the "Track Presets" folder. If they are in the root, they don't show up. So, for anyone looking for the quick and dirty steps for this for PT12 (and likely 11 too):
1. Create a Track Presets (plural) folder under Documents / Pro Tools
2. Create your track preset sessions, select the tracks you want to have as part of the preset and Export them as a session to the folder you just created. HOWEVER, you need to put them in logical subfolders like maybe 2Bus, Vox, Cue, etc.....whatever.
3. Once saved, go to explorer or whatever it's called in Mac-land and change the file suffix from .PTX to .PTXT making it a template.
4. Now when you use the new track dialog, you'll see your subfolders listed under the track type drop-down and you can select any of your self-created presets from there.
Old 10-04-2015, 08:32 AM
musicman691 musicman691 is online now
Default Re: PT 12 Track Presets hack
You can save a step when you do the export and that's to change the file extension right there; been doing that on my iMac. Do note that you may have to restart PT to see the new presets.
Jack
QAPLA!
Old 10-04-2015, 09:00 AM
Trasher in my signature will create the main folder along with quite a few categorically layer out sub folders.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
Old 10-05-2015, 04:37 AM
Thanks for the info guys. Good stuff.
Old 10-05-2015, 07:45 AM
Oliver M Oliver M is offline
Or use the AppleScript I wrote, thats Mac only of course. ;-)
Old 10-16-2015, 11:06 AM
jimreeves jimreeves is offline
Default Re: PT 12 Track Presets hack (for window7 PT12HD+)
I figured out the PC/MAC difference. Create the "Track Presets" folder in the: User/Your Username/Documents/Pro Tools/ Track Presets. Not in the Programs(x86)/Avid/ Pro Tools folder.
Old 10-16-2015, 11:19 AM
YYR123's Avatar
YYR123 YYR123 is offline
Would like to see this implemented by Avid please!!
Pls put this up front for all to use w/o work arounds
Daniel
Old 12-09-2015, 07:32 AM
JFreak's Avatar
JFreak JFreak is offline
This was possible in PT11 as well. I wonder why it isn't an official feature yet. Especially as everyone at Avid must know we're using it already.
12.4 perhaps? Not holding my breath as I've been using this for ages.
Janne
Old 12-09-2015, 01:07 PM
You're kidding - PT12 doesn't officially have this? You still have to do the workaround?
Jack
QAPLA!
Old 12-09-2015, 01:08 PM
YYR123's Avatar
I know it's ludicrous.... proTools 10 was the first version that I believe we could do this track preset with
Daniel
Track Presets [solved] jkeefauver Pro Tools 12 9 01-29-2018 10:36 AM
Track Presets Kenny Gioia Tips & Tricks 30 01-31-2014 05:33 PM
Track presets in 11? albee1952 Pro Tools 11 2 06-24-2013 05:37 PM
Track Presets!!! albee1952 Pro Tools 10 8 12-29-2012 09:13 PM
Track presets in PT??? dgkenney Pro Tools TDM Systems (Win) 3 12-22-2009 11:03 AM
