Pro Tools using Focusrite Scarlett 2i2-working!!
I just bought PT 12.2 and have been trying to use my Focusrite Scarlett 2i2 interface instead of my Fast Track Duo box (as it has a high pitched annoying whine in my headphones!). I saw several forum posts about problems interfacing the Scarlett with PT, and tried some of the fixes, but no solid fix.
Through further experimentation, I found the answer, at least in PT 12. Yes, you can have your Scarlett selected in Win(7) as the default audio record and playback device. The real fix was: Go into PT, and in Setup, make sure Scarlett is selected in Hardware and Playback Engine AND set the H/W Buffer size to 512 samples. Make sure Dynamic Plugin Processing is ticked. THIS fixed the issues of loud white noise instead of audio. Just to be safe, before you insert a track in your session, also go to I/O in Setup and delete existing In Out paths and install new ones. In my case I used a mono in and a stereo out. Hopefully, this will save others the headaches! |
Re: Pro Tools using Focusrite Scarlett 2i2-working!!
Glad it is working for you, but recording at 512 will probably have way too much latency.
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Focusrite Scarlett interface not working | michaelray1284 | Pro Tools | Intro Discussion | 5 | 09-11-2015 04:42 PM |
Focusrite Scarlett 6i6 not working with PT10 | ruS_giB | Third Party Interfaces | 9 | 08-11-2015 07:26 AM |
Pro Tools 11 with Focusrite Scarlett 18i20? | hermonmusic | Third Party Interfaces | 24 | 06-27-2015 08:53 AM |
Focusrite Scarlett 2i2/Pro Tools Express Error | pjh567 | Third Party Interfaces | 2 | 07-24-2013 11:11 AM |
Pro Tools 9 and Focusrite Scarlett 8i6 - Problems! | willyguitar | Pro Tools 9 | 0 | 11-28-2012 03:57 AM |
