Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Duet & Pro Tools | Quartet
Old 08-23-2015, 01:00 PM
bollam92 bollam92 is offline
Default Driver doesn't want to install on Win 7
Hey all,
Recently purchased a Pro Tools | Duet interface. Setup and installation was fine on my custom PC (running Windows 7 64 bit) but when I tried to install the driver on my laptop (running Windows 7 32 bit), it simply quits after the progress bar gets to "Control Panel Installing" (after "vcredist_x86 installing"). I am definitely running it in Administrator mode. It kind of installs some corrupted version of the PT IO control app but when I open it it's basically a blank gray window. Any ideas on what might be the problem?
Thanks
Old 05-17-2018, 10:22 AM
MichaelJackson MichaelJackson is offline
Default Re: Driver doesn't want to install on Win 7
Wow...i have the exact same problem with my Pro Tools Duet on a Win7-System (32bit) Home Premium and Professional.
There seems to be no way for a solution.
I have a Mac, too. There is no problem. The Firmware of the Unit is up to date. The Unit works fine. The USB-cable is fine.
But I need the Duet for my older projects on Win!
Any suggestions?
Old 06-18-2018, 01:21 PM
YYR123's Avatar
YYR123 YYR123 is offline
just a guess but I would imagine it's a 64bit driver.
Daniel
Tried installing driver while mbox was on. Now cannot install new driver breathwater FireWire and USB Audio Interfaces (Win) 1 08-20-2014 09:07 PM
Mbox 2 new driver for Mavericks just doesn't work arjohe FireWire and USB Audio Interfaces (Mac) 3 08-01-2014 05:09 PM
Wave Driver doesn't seem to work at all... GiantMan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-21-2004 04:06 PM
ASIO driver for REASON doesn't work! catalyst718 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-12-2003 03:56 PM
New Midiman USB Driver doesn't work! Watch Out! KaiXXX 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 01-04-2002 07:07 AM
