#51
Re: "Write to All enabled Shortcut" not working...
I think most of us have worked out that there's a workaround - but I don't want a workaround, I want the slash key back on the numeric keyboard.
As it stands, there are key commands which work in the US, but not elsewhere. Avid must be the only company in the world that thinks that kind of situation is acceptable. |
#52
If you select the area that you want to use the Write to current "cmd+/" (numeric pad), then click the Edit menu and cmd + / it will work. non-us keyboard.
Marco Bernardo Dialog Editor, Sound Designer, Re-Recording mixer nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro |
#53
still not working in 12.3.1.
Mac Studio, 32GB, PTHD2022.7, OS 12.5.1, S3, Transport, (EuCon 2022.4.0.78) LIO-8 BlackmagicDesign UltraMonitor3G Reaper 6.66, Fireface UCX MacbookPro M1Pro PTHD2021.12 MacOS12.1 BlackmagicDesign UltraMonitor3G MOTU 24Ao AppleTB3toTB2->AppleTB2->Ethernet->AVB |
#54
I just tested with a applescript and is working..
ahh from the Edit/Automation I think the Write to Current and the Write to all enable aren't the only ones that's not working... Here is the scripts if you want to use them... I know it's not the same as the shortcut.. but.. it is what it is. Download here - and read the readme file ps: this is free, you don't need to have Maestro or Quickey or any other paid application to use it. Regards
Marco Bernardo Dialog Editor, Sound Designer, Re-Recording mixer nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro Last edited by Marco Bernardo; 11-26-2015 at 04:28 AM. |
#55
With Keyboard Maestro it's very easy to bring back cmd-alt-/ ti life with a menu shortcut .....but please Avid it can't be difficult to fix!!!
#56
I had the exact same issue, I posted it in a previous message in DUC. I also us Quickeys, so I made a Quickey and the issue went away..
I should also point out that I can no longer create my own keyboard shortcuts via the Mac OS keyboard shortcut feature...for whatever reason they just don't work.
Cory Rizos, CAS Re-recording Mixer/Sound Designer Montreal, Quebec http://www.imdb.com/name/nm0007185/ coryrizos.com Last edited by Cryos; 11-27-2015 at 03:14 AM. |
#57
BTW I have a US keyboard and the shortcut does not work on either / key, numeric or next to right shift key. PTHD 12.3.1/OS 10.8.5/HDX Serge |
#58
Bump bump bump. Please fix this Avid. Every time I want to us the shortcut I have to change the input language to US english. You guys really know how to screw up a workflow. What next? Bins in the region list?
[email protected] Newcomer Audio Post MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... |
#59
https://www.dropbox.com/s/k3338kfz5o...19.29.jpg?dl=0
Marco Bernardo Dialog Editor, Sound Designer, Re-Recording mixer nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro Last edited by Marco Bernardo; 12-12-2015 at 02:34 PM. |
#60
Thanks Marco. It helps.
Shortcut "Write Automation to all enabled parameters" on Mac Book Pro | mecderue | Pro Tools 11 | 5 | 10-06-2015 10:45 AM |
"Write To Current" KB-shortcut missing | Nicklas | macOS | 0 | 07-06-2012 02:27 AM |
How is "Automation Write to Stop" working in PT 10 | made | Pro Tools 10 | 1 | 11-17-2011 01:53 PM |
"write to all enabled parameters" shortcut not working | Eric L | Pro Tools TDM Systems (Win) | 3 | 05-05-2007 07:49 AM |
Looking for "Write to All Enabled Parameters" LE equivalent | CCash | Pro Tools TDM Systems (Mac) | 1 | 05-15-2002 05:39 PM |
