Opening ancient sessions
Hi folks. I've recently found a stash of old archived data disks of projects from waaaaaay back, as far back as 1998/1999, and I'd love to be able to open them up to revisit them. PT 11 on the other hand isn't so excited about the prospect, the files are greyed out when I try to open the sessions.
I would guess that these go back as far as PT4 for sure, maybe even PT3, so I know it's a bit of a stretch, but is there a way to open these things up? Thanks. |
Re: Opening ancient sessions
I can't remember... what was the session file format back then (SongName.xxx)? Have you tried to import session data from those old sessions?
Try making news sessions and importing the tracks to covert to wav. |
I don't know what the session format was, it doesn't actually give me an extension at the end, I do have a super low-res PT icon (reel to reel, no less!), some of which have a "4" in the top left corner.
I don't seem to be able to Import Session Data, when I try to select the old one, it's greyed out and doesn't let me in. They are SDII files, but I haven't even gotten to audio file compatibility just yet. |
Hi Greenwire,
Unfortunately, sessions from Pro tools 4 and lower are no longer supported on PT 11. You may check the info on the link below. Under "Additional Requirements" http://avid.force.com/pkb/articles/e...m-Requirements Best Regards, YD |
Dear Moderator
What does this mean... "unfortunately sessions from ProTools 4 and lower are are no longer supported..." WHAT? Are you serious? Look, my ENTIRE archive and production process for eleven production rooms is built on an historic foundation of ProTools backwards compatibility. You guys have provided that backwards compatibility since I started with you back in the days of ProDeck and Sound Designer. I've stayed with you too... in large part because of broad backwards compatability. I've faithfully bought each upgrade, defended PT, stuck in there during the many expensive and difficult hardware and software twists and turns since 1992. Now this? "Doesn't support pre 4.0" won't cut it, guys. Pre PT4 HAS to work for me (and I bet for a lot of other folks in broadcast) It HAS to work in real time, without quirky museum robbing retro-tech workarounds, and it HAS to work in our primary rooms. I have an archive of 30+ TB of fully produced core content representing over six thousand broadcasts. This goes back to 1994. Since we made the jump to PT5 in about 2000, that means I have almost a million dollars in labor invested in editing content within ProTools V1b thru v4. (I spent that over an eight year span from 1993ish-2001ish, and it is still valuable work.) Now...half of it is just GONE? Bottom line, you just cut me off from almost half my archive. That won't work. There has to be a better answer than "no 4.0 or earlier session access". Last edited by CoolBlueGlow; 11-04-2015 at 10:32 AM. |
Progress is a biatch ain't it?
Better keep an old system alive. For anything you actually might want to use in the future, you might want to open the sessions and consolidate the files to BWAV so you can at least access them on some system going forward. I imagine you can pick them up cheap on ebay. I am somewhat curious if older sessions will open on PT 10 though, not that I have any that are worth opening. Seems once a project is finished it should be put to bed. Masters are another story, but they probably don't live only in Pro Tools sessions anyway. What's your archive format for 17 year old sessions? Hard drives sometimes die a slow death just from disuse, and tape systems probably aren't compatible with you current system either. Or you could do what some in the film industry do, and save everything to Mag. Got a warehouse to store everything in? Just saying it's not really reasonable to expect backwards compatibility forever.
Save early and often! (or once a day whether you need to or not...) |
i would make a call to Avid and talk this through with them .. do you have a computer and pro tools system that will run pro tools 6 or 7 ?? if so, you should be able to open those PT3 & 4 sessions as they did not change the PT session file format until PT7 .. it could be as simple as having an older Mbox and a computer that would run that system .. my friend just tossed an old G3 that probably would run those sessions - if i would have read this i would have taken it and shipped it to you .. http://avid.force.com/pkb/articles/e...ility/en353093 those were sound designer II audio files .. maybe avid can convert these for you .. i would hope they have some older systems still around .. maybe .. sorry to hear this, if i find some solution for you i will come back and post .. cheers john
See Rail Jon Rogut's SDII-to-Wave.
Cheers,
SD2 is not the problem here, they will convert on import
the problems are: 11+ drops old session formats (this is what the 10 license is for) Mac's back in that day (were talking OS8/9) did not attach the .xxx to files by default
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Sessions Not Opening | ffzeus | Pro Tools 10 | 3 | 02-06-2013 09:56 AM |
Opening Old Sessions in PT 8 | wwittman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-27-2008 09:34 PM |
Opening LE 7 sessions on LE 6.1 | model.citizen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-16-2006 09:04 PM |
OPENING 5.0.1 SESSIONS IN 4.3--HELP!!! | pobox7310 | Pro Tools TDM Systems (Mac) | 4 | 11-26-2000 05:28 AM |
Opening NT Sessions | Jim Morris | Pro Tools TDM Systems (Mac) | 5 | 09-11-2000 12:31 AM |
