Old 03-19-2015, 01:11 PM
materialobject materialobject is offline
Default Looping + Zero Point Crossings. etc
Hi.
Ive just started using Pro Tools 11 so everything is quite new to me.
Im using PT to produce music. I've come from Ableton Live and before that (in the 90s, Logic)
my question is pretty simple. Im recording various regions from external hardware into PT. Some of these regions i want to loop, however many times..
my issue is after recording something and looping it, im hearing clicks where the loop point is, because the loop point isn't at a Zero point crossing...
I've been using Ableton for so long i've almost forgotten what life was like before it when you had to manually make a loop LOOP by editing the start and end of the file..
My question is this, are there any automated / shortcut / quick ways to grab a region of audio in PT and tell it to Loop that and somehow magically remove the clicking at the loop point or must i dive into the audio and manually fix it up, for each region?
Any help is appreciated. thanks!
Old 03-19-2015, 01:44 PM
joachim's Avatar
joachim joachim is offline
Default Re: Looping + Zero Point Crossings. etc
Maybe :
select that audio, Ctrl F (win) to open the fades dialog, set new fade out/in time (maybe 1 msec), consolidate that audio by Alt Shift 3, and use the loop tool from there on.
Consolidation is necessary, since unconsolidated fades will be ignored by the loop tool.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 03-19-2015, 01:50 PM
Wow! thanks. this does appear to solve the issue and is very quick to do. Thank you
How do Insert an in point and out point in my tracks and play this as a loop. scottee Windows 2 08-15-2012 09:08 AM
Command to Find Zero-Crossings for Edits? Deirdre B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-09-2009 02:11 PM
Clicking on punch in...zero crossings...need help. dizzyzuma 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 09-25-2004 02:51 PM
About Zero crossings d_matt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-04-2004 04:49 AM
search zero crossings in LE? drop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-26-2003 08:30 PM
