Old 02-01-2015, 04:16 AM
Ienjoyaudio Ienjoyaudio is offline
Default Still experiencing delay compensation bugs in 11.3
The problem comes when trying to re-record multiple audio tracks to a new audio track using internal buses.
When tracks going out 1 main buss it works just fine. When prints stems or processed tracks, Delay comp is nowhere to be found even though it says its on.
Anyone else still getting this?
Need a fix to continue using my workflow.
EDIT: The scenario is comping a 100+ track session down to around 30 tracks while adding some processing on the way. Probably a total of 15-20 internal busses recording at the same time
Mac Pro 5,1 2.4GHZ 8 core
OSX 10.8.5
PTHD 11.3
HD Native
HD MADI
Artist Mix
Old 02-01-2015, 01:10 PM
Chief Technician's Avatar
Question Re: Still experiencing delay compensation bugs in 11.3
Are any of your tracks using dummy buses as outputs? A dummy bus is a bus that is not routed to a physical interface output.
Old 02-01-2015, 05:33 PM
The Fez The Fez is offline
Default Re: Still experiencing delay compensation bugs in 11.3
I've had protools 11.3 for a month of steady tracking and have had nothing but trouble with delay comp. Sometimes it works and suddenly my trax are way off the click and the delay coming off the monitors is crazy bad. There's no way Avid fixed this bug.
Old 02-01-2015, 08:20 PM
DC-Choppah DC-Choppah is offline
You need to set the preference to 'override automatic low latency mode' if you are trying to record on audio tracks and aux tracks at the same time when using delay compensation. Otherwise audio tracks will be set to low latency which means they are NOT being delay compensated while the aux tracks are being compensated.
See: http://duc.avid.com/showthread.php?t=363328
ProTools 11 manual pg 947
In certain dubbing workflows you may want
to cascade bus recordings to multiple tracks.
In these cases you should be sure to override
Low Latency Monitoring on the recording
tracks.
DC-Choppah's Project Studio:
ASUS P5Q Pro Turbo /Intel Pro 2 Quad Core-rackmount PC
Windows 7 professional 64 bit
Pro-Tools 11.3.1
AIR Instrument Expansion Pack v2
WAVES Platinum plugin bundle
M-AUDIO FastTrack ULTRA 8R Interface
Roland RD-300 / Novation XiO Keyboards
Mackie 12 channel Analog Mixer
Adam A8X monitors
Estonia Parlor Grand Piano
Yamaha Studio Drum kit
https://soundcloud.com/dc-choppah
Old 02-02-2015, 08:07 AM
tracks.
Thats it!
I had just been clicking I for input monitoring on the record tracks. I just turned that off and made them record armed instead. All delays were compensated for then.
Just curious, you have said turn off the preference. I looked in the preferences menu and couldn't find an option the way you worded it. Is there something in the preferences menu to check on and off? Or is it simple don't click I or use input monitoring?
Anyway thanks for the fix and information. Cheers!
OSX 10.8.5
PTHD 11.3
HD Native
HD MADI
Artist Mix
Old 02-02-2015, 08:41 AM
If a dummy bus is the same thing as an "Internal bus" then yes. They are all dummy busses. None of the buses were routed to any of my analogue outputs.
I work in two phases, premix,compdown, where pick what mics I like best from the original session, add a minor amount of compression or EQ. Then print down the comps to 30 to 40 tracks all internally using "Internal" or "dummy" busses.
Then I send everything out their own analogue outputs to my summing console and start the final mix.
OSX 10.8.5
PTHD 11.3
HD Native
HD MADI
Artist Mix
Old 02-02-2015, 09:39 AM
I hear you. Even though this particular problem was solved, I still get random delay comp farts. Out of no where everything goes out of phase. Usually I close and reopen the session and everything is fine.
There are some particular plugins I have that I can not use due to the fact they never are compensated for properly.
There are still issues and a fix is needed in a dot. update.
OSX 10.8.5
PTHD 11.3
HD Native
HD MADI
Artist Mix
Old 02-02-2015, 10:34 AM
Post Re: Still experiencing delay compensation bugs in 11.3
Not quite. An internal bus that goes somewhere is not a dummy bus. If you use an internal bus to feed an audio track for printing, that is not a dummy bus.
Please allow me to clarify my prior statement. If you have an internal bus that neither feeds a physical output or acts as an input to another track, then it is a dummy bus. These dummy buses will break delay compensation.
Old 02-02-2015, 12:33 PM
Ahh. I see. Then there are no dummy busses. Every mono and stereo bus was being used to print from the original audio tracks to a newly recorded audio track.
OSX 10.8.5
PTHD 11.3
HD Native
HD MADI
Artist Mix
Old 02-02-2015, 02:03 PM
I see no preference option to select 'override auto low latency mode'
Please be more specific.
tracks.
help fixing plugin delay and delay compensation disaster prestonhavill macOS 14 12-24-2014 03:35 PM
experiencing 3 second delay beefstew Pro Tools TDM Systems (Mac) 1 09-27-2006 11:12 AM
experiencing 3 second delay beefstew Pro Tools TDM Systems (Mac) 3 09-27-2006 10:07 AM
Experiencing a delay on playback when recording a new track ronmills Tips & Tricks 2 08-16-2001 05:31 AM
