Old 01-13-2015, 02:05 PM
dpolcino dpolcino is offline
Default Remove ExHUI.exe?
Upgraded to the latest eucon software and on Windows 8 startup I get a dialog box warning "Windows cannot find ExHUI.exe. Make sure you type the name correctly and try again".
Is this leftover from the previous install? How do I get rid of it?
Thanks,
Dave
Old 01-19-2015, 01:50 AM
Default Re: Remove ExHUI.exe?
Yeah, so I did a big uninstall, cleaned the registry as best I could, and the exHUI.exe not found warning goes away.
I reinstall the latest EuControl software and the warning comes back.
So is there a problem with this latest installer or something? Did exHUI.exe get left out of the install package, or is some old version code still hidden somewhere?
Help would be nice, thanks!
Old 01-19-2015, 01:20 PM
Thanks for looking into it. The firewall was a good idea, but there's nothing in the relating to exHUI.exe.
The warning that pops up is a dialog box that has to be dismissed, i.e. "Warning! Windows couldn't find exHUI.exe" then you have to click OK.
Like I said when I remove EuControl software this warning goes away.
I'm guessing that the installer doesn't have exHUI anymore but most people when they upgrade still have it from the last install. Avid please confirm.
Old 04-13-2015, 08:19 AM
putney putney is offline
I have the same problem here.
Can Avid reply with a solution?
Thanks,
Russell
"What's the best mic under $100."
Old 04-13-2015, 08:24 AM
To answer my own question:
Go to 'all programs/startup' and delete Euconstart
Old 02-15-2016, 04:30 AM
Glad I posted this a year ago! The latest installer brings back this problem so I was able to search for it to remember how to fix. Kind of weird.
Old 02-19-2017, 11:21 PM
funkybass funkybass is offline
For windows users, go to the search bar on the start menu type "msconfig" (no quotes) hit enter, then click the startup tab at the top, uncheck the "EuConStart" click ok and restart your PC.
Hope this help. Good luck.
ExHUI process on Eucon/Hybrid MAC Tim R. System 5 1 01-15-2013 09:08 AM
cannot remove pop crashhak Eleven Rack 2 11-13-2010 10:36 PM
Does remove PT - remove projects too? Andy Gerome 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-29-2008 11:29 AM
Add/ Remove Programs will not Remove Pro Tools powerjoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-07-2005 02:48 PM
Remove OSX? pag113 Pro Tools TDM Systems (Mac) 3 10-14-2002 05:36 AM
