Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Mac)
Old 12-26-2014, 02:06 AM
Edwud Edwud is offline
Default M-Audio Keystation 49 (New 2014) transport buttons in Pro Tools
Hi! How to configure transport buttons and directional buttons M-Audio Keystation 49 (2014) in Pro Tools 8?
Doesn't work, they just play notes.
Use Mac OS 10.9.5, Pro Tools 8.0.5
Works well in Logic Pro X and Ableton.
Old 12-26-2014, 09:36 AM
Bill Denton Bill Denton is offline
Default Re: M-Audio Keystation 49 (New 2014) transport buttons in Pro Tools
You will probably have better luck looking on the M-Audio site.
You will need to determine if Pro Tools is actually supported...it uses a different "control protocol" than that used by the other DAWs...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 12-26-2014, 11:15 AM
I write on the site m audio, they simply ignore me. I decided to write here.
Old 12-26-2014, 05:25 PM
I did some additional checking...supposedly it will work, but I could not download the manual for the new unit (M-Audio server problem).
The only information I could find was this...http://m-audio.com/kb/article/1651
It shows how to set the Keystation for HUI mode...do that, then go to Peripherals Setup and follow those instructions. I don't have any of the older Pro Tools documentation so I can't help you farther.
Sorry I can't be more help...good luck!
X
Bill in Pittsburgh
Old 12-28-2014, 03:12 AM
Tnx for help! I will try to find a solution.
Getting plugin drum machine to sync with Pro Tools transport buttons?? leonlive Pro Tools M-Powered (Win) 0 07-22-2008 01:13 AM
Keystation Pro 88 and PTMP 7.1 Transport Control DrChumley Pro Tools M-Powered (Win) 1 11-10-2006 09:56 AM
Keystation Pro 88 knobs and buttons? DaveBMusik MIDI 0 09-12-2006 06:05 PM
M-Audio Oxygen 8 v2 transport buttons AverageJoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-21-2006 09:45 AM
Pro Tools and M-Audio Keystation Compression Records Pro Tools TDM Systems (Mac) 0 02-04-2005 06:49 PM
