Old 12-18-2014, 03:35 PM
freakhouse freakhouse is offline
Default Can't change sample rate in Core Audio Manager
I've got a HDX rig. When I go into Core Audio Manager the sample rate is set to 44.1 and everything else is grayed out. I want to set it to 48k. I've tried trashing my prefs but that did nothing.
Old 12-18-2014, 04:47 PM
Top Jimmy's Avatar
Default Re: Can't change sample rate in Core Audio Manager
Is the Avid CoreAudio manager still installed with Pro Tools? If so, use it. If not, then open pro tools and create a new session at 48K. Quit pro tools. Your interface should still be at 48k.
James Cadwallader
Old 12-18-2014, 05:01 PM
Thanks for your help! Yes, Avid CoreAudio manager is still installed. I'm running 10.3.9 I tried your suggestion and it stuck on 48k when I left the session. Definitely a good workaround. If I go back into CoreAudio manager it sets back to 44.1 and everything is still grayed out. Is CAM worthless now for changing sample rates?
Old 12-18-2014, 05:56 PM
Top Jimmy's Avatar
Are you using the Avid interface as your default Mac OS audio device? If so, you shouldn't be. Change the Mac back to onboard and see what difference that makes.
James Cadwallader
Avid Core Audio Manager don't change the Sample Rate catuser Pro Tools 11 0 04-22-2014 11:48 AM
PT9 Sample Rate with Core Audio tvoc macOS 1 06-27-2011 01:17 AM
Pro Tools LE 8.0.3 Audio File Length change upon import / Sample Rate issue PhillyMike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-10-2010 05:49 PM
How do I manually change the sample rate on 002R with Core Audio? rastro2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-14-2008 08:46 AM
change sample rate info for audio file djd2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-27-2007 05:19 PM
