Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 10-28-2014, 07:26 AM
Lundy North Lundy North is offline
Default Mezzo...
I have an iLok licence for Mezzo 4.7 and the Mezzo 4.7 software, on an OSX10.4 machine.
Over a year ago this all worked and I was able to extract some projects.
Today when I run Mezzo I get a dialog window stating: "Required software extensions are missing", " Click OK to be transferred to the PACE website"
When clicked it takes me to the iLok website with an error 404.
I do have a file I saved called "interlokextensions.hqx" but I have tried plonking that file in lots of places but no joy.
I know it's a huge ask, but can anybody offer any suggestions?
While I'm here, may I just say a big thank you to Steve Kellogg, and his brother Jack, I think, the creators of Mezzo, a company called Grey Matter Response I do recall, you really did shaft us, I'm sure I will bump into you one day, and I will be able to thank you in person
Old 10-31-2014, 09:11 AM
Default Re: Mezzo...
Sorted it, just had to install the legacy non-intel pace drivers from here: http://sw.ilok.com/macextsx_legacy.dmg
Old 03-04-2015, 10:55 AM
heyjcjc heyjcjc is offline
Hey, thank you for that link, I'd gotten the same error and was trying to track down the 4.7 installer. However, now I'm getting the error "An exception of class NilObjectException was not handled. The application must shut down." Have you run into that before?
Old 03-04-2015, 10:56 AM
The G5 that has Mezzo is running 10.5, btw
Old 03-24-2015, 10:49 AM
Figured I'd keep an online log of the steps I'm taking to resurrect these tapes. If anyone needs the PACE installers or ATTO drivers or the configuration tool installer, or the Mezzo 4.7.4 installer, I have them and can email. I'm running into the issue that Mezzo boots up and the PCI card seems to be working, however Mezzo isn't listing the tape drive in the application itself. ATTO Configuration Tool shows a SCSI device present. Huge thanks to everyone that has helped me out on here, btw, and the guys at BMS Chace Nashville. If anyone has any info that could be helpful, I'd be truly grateful. As of now, the software I installed is a clean copy of OS X.4.11, Atto Configuration, Atto drivers and Mezzo 4.7.4
"As of 24MAR2015, 12:40 p.m.
Installed Apple OSX v10.4.11
Installed ATTO Express PCI Plus v3.21
Installed ATTO Configuration Tool v3.07
ATTO Express PCI UL3D SCSI-2, PCI SLOT-2
ATTO ExpressPCI UL3D:
Type: scsi-2
Bus: PCI
Slot: SLOT-2
Vendor ID: 0x1000
Device ID: 0x0020
Subsystem Vendor ID: 0x117c
Subsystem ID: 0x8007
ROM Revision: 1.6.6f0
Under Parallel SCSI Device Tree: (when top rack unit is plugged in and powered)
SCSI Parallel Domain 0:
Initiator Identifier: 7
SCSI Parallel Domain 1:
SCSI Target Device @ 6:
Manufacturer: SONY†
Model: SDT-±0000 †
Revision: 0101
SCSI Target Identifier: 6
SCSI Device Features: Wide, Sync
SCSI Initiator/Target Features: Wide, Sync
Peripheral Device Type: 1
SCSI Logical Unit @ 0:
Manufacturer: SONY†
Model: SDT-±0000 †
Revision: 0101
SCSI Logical Unit Identifier: 0
Under Parallel SCSI Device Tree: (when bottom rack unit is plugged in and powered)
SCSI Target Device @ 5:
Manufacturer: SONY†
Model: SDX-µ00C †
Revision: 0102
SCSI Target Identifier: 5
Manufacturer: SONY†
Model: SDX-µ00C †
Revision: 0102
Tried both Rorke Data rack units. Neither recognizes tapes are loaded in Mezzo, nor does it list the tape drives. Under Device Status in Mezzo, only CD/DVD has anything listed, and it lists the Pioneer DVD-RW DVR-117D (B705) via ATAPI.
Top unit bay one is empty, bay two has DDS drive
Top SCSI ID reads: 5
Bottom SCSI ID reads: 6
Bottom unit bay one has unmounted scsi drive, bay two has AIT drive
Top SCSI ID reads: 3
Bottom SCSI ID reads: 5"
Old 07-07-2015, 01:00 PM
Default Re: Further adventures in Mezzo...
Still no luck in getting Mezzo to see the tape drives. Minor developments:
1) When rebooting, the tape drive cycles.
2) Was on tech support with ATTO, everything looks to be in order as far as the ExpressPCI UL3D goes.
3) Had a friend install OS 10.3.9 on another partition and installed all the software needed (as far as I know), still no luck with Mezzo seeing the AIT drives.
Does anyone still have a working Mezzo 4.7 system that's using a dual G5 tower with either OS 10.3.9 or later? I'm wondering if I could clone a working system drive to rule out any missing extension or firmware issue.
Thanks everyone for your help!
Old 02-05-2016, 05:44 PM
FYI, Have 10.3.9 up and running with 4.7 Mostly stable, sometimes crashes
Old 01-03-2019, 06:23 PM
Steve M Steve M is offline
Would anyone be willing to sell the ilok with 4.7 ? or rent it?
Old 01-04-2019, 03:06 AM
Jandini's Avatar
Jandini Jandini is offline
Hi Steve,
I have created my own Mezzo 2.x and 4.x restoration Software.
As the software is not “production ready” yet, I’ve been offering Mezzo tape restoration as service. Also remote restoration service if you don’t want to send the tape(s). I’ve successfully restored number of mezzo tapes from Sweden, USA and Poland.
If this is something you’d be interested, let me know. I’m happy to help.
Best Regards
Matt.Janda
.Kingston At gmail.com
Matt
Old 07-20-2021, 04:24 PM
Originally Posted by Jandini View Post
Hi Steve,
Best Regards
Matt.Janda
Hey, Matt, did you get that software production ready? The studio computer is still running 4.7.4 thankfully, just curious at this point. Is there an ilok workaround?
Cheers,
-J.C.
Mezzo andrewb Pro Tools TDM Systems (Mac) 5 06-03-2012 10:08 PM
MEZZO HELP Tell Pro Tools TDM Systems (Mac) 3 03-23-2004 07:09 PM
Att Mezzo users ...How good/effective is background back up of Mezzo dw Tips & Tricks 7 07-25-2000 10:18 PM
Mezzo And AIT? Ciaran1 Storage Subsystems 8 06-03-2000 05:01 PM
Mezzo/PT5? Eric Bazilian Pro Tools TDM Systems (Mac) 14 04-09-2000 12:29 AM
