Hardware insert delay compensation fail.
It appears that the only way to use Hardware Inserts on a channel is to bus it to an Aux first. The delay compensation fails to work if the IO is inserted directly onto the channel.
Does anyone know why or can explain what I'm missing in prefs or settings? (Running 10.3.8 on TDM, but have a colleague with the same issue running 11 Native.) |
Re: Hardware insert delay compensation fail.
I wasn't aware of settings available on the IO page, but many thanks I am now. I will investigate.
Unless you are on an HD/HDN/HDX system, you must manually input your comp on inserts. it's a pita to be quite honest.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Pro Tools 9 Hardware Insert Delay Compensation with Lynx AES16e and Aurora 16 | SolutionRoom | macOS | 0 | 04-08-2011 10:54 AM |
Setting up H/W INSERT Delay Compensation | teacherman | Tips & Tricks | 16 | 11-17-2010 02:30 PM |
Hardware Insert Delay value for 888/24??? | cronos | Pro Tools TDM Systems (Mac) | 3 | 01-29-2010 06:50 PM |
Hardware Delay Compensation | loosestones | Pro Tools TDM Systems (Mac) | 0 | 04-07-2009 11:51 PM |
Analog insert Delay Compensation | midnightsun | Pro Tools TDM Systems (Mac) | 7 | 02-16-2008 10:32 AM |
