Old 08-06-2014, 03:32 PM
johnsimmons johnsimmons is offline
Default 11.1.3 -9173 every time you insert a 3rd party plug question.
I'm tired, I've spent a day off doing a new install of everything from os 10.9.4 to all plugs, new drive, imac i7, thunderbolt omni/native setup ,all troubleshooting in an attempt to get a smooth running session. EDIT: having gone from similar problems on 10.8.5 and other versions...
Are other professionals out there doing PT sessions, audio and VI, 30 tracks for example, where you expect to have a -9173 error every time you insert a (3rd party) plug on a playing session bringing all to a halt with error message?
Really at wits end with every cent i've spent on my whole setup and aax rebuying etc etc etc ....
Old 08-06-2014, 04:06 PM
Bob L's Avatar
Bob L Bob L is offline
Default Re: 11.1.3 -9173 every time you insert a 3rd party plug question.
You've absolutely confirmed that every plugin on your machine is the latest and compatible version? Not just ones your trying to instantiate, everything in the plugins folder? No wrapped VST or AU? No old demos hanging around?
Trashed prefs? Repaired permissions?
Any chance to roll back to 10.8.4?
Bob
Old 08-14-2014, 03:06 PM
jryser's Avatar
jryser jryser is offline
Just upgraded to 11.2.1 and having the same issue. Had it in 11.2 NOT in 11.1.3. Very frustrating.
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
Old 08-14-2014, 04:15 PM
jryser's Avatar
And it is only when I try to bounce in real time. No issues during recording, playback, etc.
Old 08-14-2014, 04:59 PM
Bruce Paine Bruce Paine is offline
Admin Emeritus
Have you been able to test to see if it could be plug-in related?
Such as removing all third-party plug-ins from your plug-ins folder and seeing if there is any difference.
If yes, then adding your plug-ins back a few at a time until you are able to narrow down anything specific.
I'm not suggesting it is not a Pro Tools issue, but I would start with checking for any problem plug-ins to see if that is a factor.
Bruce Paine
System Details
Old 08-14-2014, 05:03 PM
jryser's Avatar
Hi Bruce - you have saved my bacon before so let's troubleshoot! Yes, I have done the third party removal. However, I am going to - on a hunch I guess - remove all plug ins and try from scratch.
Old 08-14-2014, 05:49 PM
jryser's Avatar
Ok. Did that. Took all of them out. Nothing but what 11.2.1 put in. Got the AAE-9173. Hmmm
Old 08-15-2014, 04:12 AM
For those having issues are you trying to insert a plugin while the session is playing? I have had this happen from time to time depending on the plugin being inserted but it's rare; happens when trying to insert a reverb or a plugin that does look-ahead processing. So I learned to stop the transport and then insert whatever plugin.
Jack
QAPLA!
Old 08-15-2014, 12:57 PM
CygnusX-1Bk2 CygnusX-1Bk2 is offline
I got this today with 2% total CPU in System usage. Entered bug here:
http://protools.ideascale.com/a/dtd/...79?submitted=1
Please agree!
I will choose,
Freewill
http://jimdiazaudio.com/
Old 12-05-2014, 09:01 AM
axiom axiom is offline
Did this ever get resolved. I get it during real-time bounces, even bouncing only 2 tracks. Everything is updated to the latest versions here. Not running Yosemite yet.
Will Loconto
www.WillLoconto.com
Cut/Insert Time - workflow question zakco Pro Tools 10 10 07-11-2012 12:30 PM
Insert Time playlists question summit01 Pro Tools TDM Systems (Mac) 1 10-03-2009 07:41 PM
insert plug in question billybroadsword Pro Tools TDM Systems (Mac) 5 05-15-2009 08:38 PM
Time & Pitch plug-in question dillyllama Tips & Tricks 3 09-09-2006 07:35 AM
How to insert time / insert measures, without upsetting tempo map and markers imp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-25-2003 05:45 PM
