Old 06-22-2014, 05:56 AM
jasperhb jasperhb is offline
Default AAE ERROR -30001 - with PSP VintageWarmer 2 and other PSP plugins
Anyone else having issues with using PSP Audioware AAX plugins in PT 11.1.3 on x64 Windows 8.1 (update 1)(*)?
I can use PSP Audioware plugins if I start a blank session and use no other plugins, but if I use for instance VintageWarmer2 on a more complex session with multiple tracks, busses and other plugins I will get an AAE ERROR -30001 and for every new PSP Audioware plugin I add the AAE ERROR will occure with an increment fo the error code - i.e. -30002, -30003 ... -3000n.
I've seen the error with VintageWarmer2, OldTimer, RetroQ, ClassicQ, BussPressor and more, but I've not seen it with PPM2.
Any ideas what this is and how to run Diagnostics? I've raised a support question with PSP Audioware and are awaiting their response.
Rgds
(* The PC was reinstalled from the buttom up this very week. I had the issue on the previous installation also.)
Rgds
https://soundcloud.com/1iveowl/
Pro Tools 2018.4, Windows 10 Pro x64 (w/ latest update), i9-7980XE, ASUS TUF X299 Mark II, 64 GB Memory, Samsung 850 2TB SSD, UAD Apollo Twin II TB, RME Fireface USB, UAD-2 Octo PCI, Plugins: UAD Waves, Softube, FabFilter, Lexicon, NI Komplete 11 Ult, Celemony, Slate Digital, PSP, Arturia V Collection 6, FXPansion, iZotope, SoundToys, Spectrasonics...
Old 06-22-2014, 07:15 AM
WKG WKG is offline
Default Re: AAE ERROR -30001 - with PSP VintageWarmer 2 and other PSP plugins
They seem stable for the most part but I did experience a rare crash when toggling the Fat setting on Vintage Warmer2 yesterday. I haven't seen the errors you mention though.
I7-4930K, X79-Deluxe, 2133 32 GB,
GT640, 512GB 860 Pro, 1TB Evo, WDB 2TB X2,
Win 10 Pro, PT Ultimate 2019.6 REAPER 5.963
RME, Daking, ISA, Sytek, BLA
ASUS N71Jq i7 940xm 8GB DDR3
PTHD 12.1 REAPER - Win 10 HP
Old 06-23-2014, 01:02 AM
Update: Just got word from PSP Audioware that they are working on an update that is likely to address the issue.
Rgds
Old 06-23-2014, 07:19 AM
Eric Lambert's Avatar
These PSP/AAX errors have existed for many months, no? We had to go back to RTAS for some of their plugins.
Old 06-23-2014, 09:49 AM
Yes, I've seen the error for a couple of months. It seems PSP is aware of the issue and that they are currently working on an update to the plugins.
Rgds
Old 07-18-2014, 03:16 PM
Still not fixed but I know they are trying.
Have anyone else seen this error and been able to zero in on the cause?
Thanks
Rgds
Old 07-18-2014, 03:34 PM
WKG WKG is offline
There is a beta on the VW download page. I haven't tried it but maybe it's a fix in progress?
Old 07-18-2014, 06:06 PM
Last week I went to PSP's site and downloaded all plugins again, even though the version numbers hadn't changed. After installing, all plugins which I own (and it's most of PSP's) are displayed correctly. I don't know if PSP made changes or if it's related to ProTools updates but I don't care - they're working!
Old 07-19-2014, 02:20 AM
I've gone further than that. I reinstalled the whole PC.
The tricky part is that if I start a new PT session I have no issues adding psp plugins to it, however if I try to add psp plugins to an already buzy session then I see the error.
Also, if I add a psp plugin early in a session it will continue to work even as the session grows, however it will not work if I start adding psp's late. It is really a tricky bug this one.
Btw, all other plugs I own that are axx 64-bit compatible on a PC works fine. And I own quite a few plugins gathered over the years.
Rgds
Old 07-19-2014, 09:07 AM
Yes, that is odd behavior from a plugin.
AAE -30001 Error with VTM Dot Pro Tools 11 5 03-18-2015 01:37 PM
AAE ERROR 30001 - with Slate VBC FG GRAY Seafoam_Green Pro Tools 11 7 05-13-2014 05:53 PM
Air plugins DAE ERROR 7054 MEAT Pro Tools TDM Systems (Win) 7 12-27-2008 07:43 PM
PSP VintageWarmer & MasterQ vrs Ozone.. vieris Pro Tools TDM Systems (Mac) 2 06-23-2005 06:10 AM
DAE -7401 w/PSP VintageWarmer ... whtrabit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-20-2004 11:00 PM
