Old 06-16-2014, 09:52 AM
vudoo vudoo is offline
Default Error -9093
I can work for hours and then out of nowhere error AAE -9093. This could be on a session with hundreds of tracks or simply playing one audio track with a click.
I read a lonnnnng thread about this issue awhile back so i guess it has never been fixed???
Mac Pro (cyninder) 3.5 Ghz, 6 Cores, 16 GB ram, Dual AMD D700, OS X 10.9.2
Pro Tools HDN 11.1.2, Avid IO 16 x16
There's nothing else but PT on this machine and running only Avid's plugs.
Old 06-16-2014, 01:18 PM
Default Re: Error -9093
176 views and no one ??
Old 06-16-2014, 01:48 PM
Craig F Craig F is offline
from http://avid.force.com/pkb/articles/e...ategory=Audio;
MC Control Support
Note: There is a known issue when using the MC Control for scrub or shuttle. Errors -9171 or -9093 may be encountered
only -9093 reference I could find
you say hours, is that continually on or accumulative hours?
accumulative, no idea
continually, thermal problem or long run code bug
Thank you,
Craig
Old 06-16-2014, 04:34 PM
Found the problem…rock solid performance now.
Old 06-16-2014, 04:37 PM
Bookerv12 Bookerv12 is offline
What was the problem?
bookerv12
Old 06-16-2014, 05:33 PM
It was the apple wireless trackpad. When scrolling (in mix or edit window) using the trackpad i noticed PT's meters freeze for a split second, this does not happen if i use the scroll bar at the bottom or on the side of the window.
I'm now using my Kensington trackball and all is good. Been editing and mixing a pretty big film session (Full 1080/24p Prores HQ video, over 220 audio tracks, lots of plug-ins, over 12 tracks of VI and at the same time recording VO) for the past 5 hrs and it performed flawlessly with CPU hovering at 18%. The new MP is a beast, really really powerful.
Old 06-17-2014, 04:38 AM
Cheesehead Cheesehead is offline
Hi Vudoo,
What are you using to house the native card in that rig please?
Any extra drives?
I'm thinking of going for the cylinder myself.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 06-17-2014, 08:26 AM
Hi Cheesehead,
I'm using the HDN thunderbolt so no 3rd party chassie is required.
Here's my config:
- Mac Pro Cylinder 3.5 Ghz, 6 cores, 16 GB ram, 512 GB SSD, Dual AMD D700 (i bought the fastest dual GPU card for my video needs)
- External Peragus Thunderbolt Raid (4 drives stripe in Raid 5)
- External Lacie Little Big Disk Thunderbolt 2 (for my VI and sound library)
- AJA Kona 3G in a Sonnet Thunderbolt chassie
I also have an HDX system in a 12 core mac pro. There are sessions that barely play on it that play fine with the above HDN rig.
I did another quick test this morning by consolidating a film session that required two TDM rig and it plays fine on the HDN. The consolidated session has over 200 audio tracks with either a channel strip or EQ7 + Dyn on every track, 20 reverbs from Exponential audio (i added some just for the test), heavy automations and QT movie in Prores HQ @ 1080p @ 24fps. The CPU was hovering between 16 and 20% & disk I/O 13%. I was running the whole session at 32 buffer!!!
I find the native system in the new mac pro way more powerful than my HDX1. The only advantage of HDX for me at this point is the ability to add more cards hence augmenting your total # of voices.
As for stability, both systems are about the same and by keeping the native system at buffer 32 or 64, latency is a non-issue for me when tracking, keep in mind i never track with plug-ins.
Old 06-17-2014, 03:04 PM
Thanks Vudoo,
Great info, just what I needed to hear, that sounds like an amazingly powerful setup you have there.
Do you get any problem with cpu spikes? I'm having that issue quite frequently on my HDX 1, even though cpu is only running around 30% on a big film session.
20 Exponential reverbs, wow! Are they 5.1 or stereo? Not that I would ever need 20, but wow anyway.
Old 06-18-2014, 12:21 PM
Yes i do get occasional CPU spikes on both HDX and HDN system. It mostly happens when using VI, even when using only Avid's own VI.
They still have some catching up to do when it comes to VI, the system becomes much less stable as soon as i use them.
Just for fun i added an Avid's limiter pro to practically every channel(close to 150 of them) to the session above plus another 10 (30 exponential reverb in stereo) reverbs and the CPU is barely hitting 25%. I'm not even sure an HDX2 has this much power.
-9093 Error Keith Moore Pro Tools HDX & HD Native Systems (Mac) 6 12-28-2013 09:47 AM
Error 9093- Need some help... cclarkaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-21-2008 06:02 PM
error 9093 Shame69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-09-2005 12:07 PM
1 Cure for error 6085 and error 9093!!!!!!!!! CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-23-2002 07:30 AM
Error (-9093) [email protected] Digidesign Hardware & Software 7 02-07-2001 03:33 PM
