Old 05-11-2014, 07:29 PM
Seafoam_Green's Avatar
Seafoam_Green Seafoam_Green is offline
Default AAE ERROR 30001 - with Slate VBC FG GRAY
Hi , every time I try to open SLATE VBC- FG GRAY Compressor in Pro Tools 11.1.3 ( Windows 7 ) ....,
I get the ..., " Plugin could not be made active because a AAE error was encountered - AAE ERROR 30001 " message ? - this is in both Audio Suite , and as an insert on a track .
Strangely enough though ..., FG Mu , FG RED and the VBC Rack all will open up no worries , its just FG Gray that doesnt open and I get the error message
I have uninstalled and re-installed VBC , but no change ?
Any suggestions
Cheers
Old 05-11-2014, 08:37 PM
Dot Dot is offline
Default Re: AAE ERROR 30001 - with Slate VBC FG GRAY
I have exactly the same error with VTM http://duc.avid.com/showthread.php?t...ighlight=30001
are you on pc or mac?
www.dominicdotokune.com
Old 05-11-2014, 09:56 PM
I am on PC (Windows 7) ...., and my Pro Tools AAE 30001 error message is with the latest version of Virtual Bus Compressors ( VBC ) and the error message only applies with the individual FG Grey Compressor , as all others including the rack are working fine .
Old 05-12-2014, 09:06 AM
sw rec sw rec is offline
Huh, just tried it here (SLATE VBC- FG GRAY Compressor ) (PT 11.1.3/Win 7) no problems at all.
When I had a similar problem with the new UA Win AAX plugins, I re-downloaded the installer, uninstalled/reinstalled and everything worked fine (it also was giving AAE errors.)
Old 05-12-2014, 10:34 AM
mesaone mesaone is offline
Whenever I get AAE errors, clearing the plug-ins database with Trasher usually works. Sometimes I am forced to uninstall and re-install the plug-in. Haven't run into any issues with VBC, but the above is what I would try first.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 05-13-2014, 06:58 AM
Hi guys , thanks for all your replies and support , its very much appreciated .
I got a helpful reply today from Slate support which worked ..., it was similar to what was suggested here , but with a few extra tips ... which got me up and running again
Here is a copy from that email from Slate support just in case anyone else receives the AAE Error message and needs to find a fix .
From Slate ;
Please delete all the plug-in components from your system, in respective plug-in folders. Delete VBC folder in C:\ProgramData (hidden by default), clean registry with Piriform CCleaner (free on the web) or other, reboot, trash PT prefs and databases, and re-install VBC 1.1.0.10.
Next, deactivate/reactivate license in iLM and run Sync/Repair on the key
- http://www.iLok.com/knownissues.html
Once again , thanks everyone .
Old 05-13-2014, 09:42 AM
Dot Dot is offline
@Seafoam_Green THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!
i did exactly what you wrote and bam, it works, even pro tools 10 aax version of VTM doesnt crash anymore. I appreciate it, it's been like month or even more that i couldn't make it work. I owe you a beer or something
Old 05-13-2014, 05:53 PM
Your welcome Dot , I.m glad you are also up and running
AAE -30001 Error with VTM Dot Pro Tools 11 5 03-18-2015 01:37 PM
FS: Slate VCC, Slate VTM, Soundtoys Radiator apesong Buy & Sell 10 05-01-2014 03:01 PM
Slate Digital and Steven Slate Drums AAX DHL AAX Plug-ins 6 04-22-2013 12:50 PM
Error 7401 when using Slate Digital FG-X shultzee13 Pro Tools M-Powered (Mac) 0 10-11-2010 02:04 PM
in the gray groovilator 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-18-2006 11:23 PM
