Go Back   Avid Pro Audio Community > General Discussion & Off Topic > Buy & Sell
Old 04-15-2014, 07:29 PM
treason treason is offline
Default MAGMA ExpressBox 4 (2U) EB4 4 Slot PCIe to PCIe EXPANSION CHASSIS PRO TOOLS HDX
For Sale - Factory Reconditioned Magma ExpressBox 4 (2U) PCIe-PCIe Expansion Chassis
http://www.ebay.com/itm/121320420377...84.m1555.l2649
Works with Avid Pro Tools HDX/HD Native
Apple MacIntosh 2010/2012 Mac Pro PCIe-PCIe
New Cost :$2499.99
When two PCIe slots aren’t enough, add four PCIe slots in a 2U rackmount chassis with a 550W power supply and dedicated cooling.
Cost-effective Solution for Expanding I/O Capacity
Magma's ExpressBox 4 provides a cost-effective path to expand the available number of PCI Express slots while maintaining consistent server or workstation configuration. The product provides increased I/O capacity and scalability.
Easy Installation:
ExpressBox 4 consists of a PCI Express Host Card, a cable and a chassis. It is automatically configured by the System BIOS making all of the slots appear transparent to the host computer.
Optimal method to enhancing your PCI Express I/O capabilities
ExpressBox 4 is an expansion solution that provides 4 full-length PCI Express slots. This is a standalone chassis in an industry standard enclosure with its own power supply. The chassis allows the flexibility to expand the I/O capabilities of a server or workstation seamlessly capitalizing on the transparency of PCI Express architecture.
Benefits:
Industrial solution for adding up to 4 PCI Express cards to one computer
Attach full-length PCI Express cards to computer with limited card space
Low profile host card allows for easy installation in low profile computers
Supports peer to peer transfers between cards in slots of the expansion chassis
Features:
Easy “Plug and Play” installation
Easily visible LEDs indicate correct installation
Includes x8 PCI Express host card and 1 meter iPass cable
All slots support any combination of x1, x4, x8 and x16 PCI Express cards
Transparent extension of PCI Express signals outside the computer
All slots support full-length cards
2U rack-mount enclosure
550W power supply
Dedicated fan for cooling hot cards
Thermistor controlled fan speeds help reduce unnecessary noise
CE certified and FCC Class A verified
RoHS compliant
FAQ:
Is it rack mountable?
Yes this unit is rack mountable via the rack ear provided. It will be stationary in the rack.
Do I need drivers?
No drivers are necessary for this unit.
Can I add hard drives to it? If so how many?
This unit provides SATA power connectors for two hard drives.
T-
Waterstreet Studio Main: MacPro 2012 (12C@3.46GHz), 48GB, Apple/Samsung SSDs, WD Blacks. macOS 13.3
DSP & IO : Pro Tools HDX2(2018.3), 2x UAD Octo, HDIO 16x16 Analog IO(3), HDIO 16x16 Digital IO
Plugins: Avid, DMG Audio, Kush, oeksound, P'n'T, Plugin Alliance, Softube, SoundTheory, Sonnox, Sound Radix, SoundToys, UAD, VEP, etc
Hardware: API, Chandler, Hardy, Moog, Neve, Shadow Hills, Smart, Summit, TC Electronic M6000, UREI, etc
Microphones: Telefunken, Neumann, Shure, AKG
Old 04-24-2014, 12:17 PM
Default Re: MAGMA ExpressBox 4 (2U) EB4 4 Slot PCIe to PCIe EXPANSION CHASSIS PRO TOOLS HDX
bump
T-
Old 05-01-2014, 01:55 AM
bump
T-
Old 05-07-2014, 02:16 AM
Now with International Shipping
T-
Old 05-13-2014, 08:30 PM
bump
T-
Old 05-21-2014, 03:52 PM
bump
T-
Magma ExpressBox 3T - 3 Slot Thunderbolt PCIe Expansion Oliver M Buy & Sell 0 04-13-2014 09:35 AM
FS: HD2 PCI-x in a Magma 2-slot chassis with PCIe card Justin1524 Buy & Sell 5 11-29-2013 01:09 PM
New Magma PCI 3 slot expansion to PCIe nst7 Pro Tools TDM Systems (Mac) 4 01-13-2013 07:55 PM
Magma Chassis host card - which PCIe slot? Allan Speers Pro Tools TDM Systems (Mac) 2 09-07-2012 09:54 PM
This is AWESOME | $290 4 Slot PCIe to PCI Expansion Chassis 25ghosts Pro Tools TDM Systems (Mac) 59 12-02-2010 07:15 AM
