Old 02-15-2014, 09:27 AM
tony20970 tony20970 is offline
Default Problem opening/installing "10.3.8.dmg" in Mountain Lion
Hello,
I have Pro Tools 11 installed on my Mac i7 and it runs perfectly. I need plug-in compatibility between PT11 and earlier versions of Pro Tools so I downloaded my copy of Pro Tools 10.3.8 from Avid so I can have PT11 and PT10 co-installed on my Mountain Lion OS.
My mac is not connected to the internet, because I do not want any automatic updating to Mavericks OS, so I can have both versions co-installed.
However, when attempting to open "Pro_Tools_10_3_8_Installer_80777.dmg" it says the disk image could not be opened. "Reason: Not Recognized". I tried dragging the icon into the Applications folder and manually trying to "mount the image" and it is "not recognized".
What am I missing here? Any and all help is much appreciated! Thank you!!
Old 02-15-2014, 09:50 AM
Default Re: Problem opening/installing "10.3.8.dmg" in Mountain Lion
Originally Posted by tony20970 View Post
Hello,
You can leave a Mac connected to the net and don't have to worry about it automatically updating to Mavericks. The Mac operating system won't do that. Back to the problem at hand - you might have a bad download and I'd try it again. You might also have to turn off sandboxing - Google for how to do that. It's a security measure that's supposed to prevent opening/running/installing programs that don't specifically have Apple's blessing.
Assuming you have a good download and have turned off sandboxing all you should have to do is to double click the .dmg file. A window will open up with various things in it; double click on the 'install PT10' icon. Also make sure you're running as administrator.
Jack
QAPLA!
i have a problem with "Pencil Tool". Why it's always in "square mode" ? ak11_lin macOS 6 08-25-2013 05:38 AM
Save as > "Could not 14404 because File or folder not found (-43) while opening "..." Elias Stiza 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-10-2012 07:06 PM
Problem Installing -- "Insert Disk containing Data2.Cab" justindbutler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-27-2010 08:06 PM
Problem Installing -- "Insert Disk containing Data2.Cab" justindbutler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-23-2010 12:07 PM
DIGI 002, Problem installing hardware driver "cannot find hardware" on install inevitable realisation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 26 08-21-2003 02:03 AM
