Old 01-30-2014, 12:36 AM
SmokinBaldMonkey SmokinBaldMonkey is offline
Default Manually played MIDI Notes arrive earlier than played.
I am pretty much ready to hurl this HDX system right out the window.
I'm running a 16 track 88.2 session with one virtual instrument (addictive drums). Buffers at 128 (lowest setting allowed by HDX engine). almost no plugins to speak of.
When I play MIDI drum notes from the keyboard (via the Digidesign MIDI IO) they SOUND fine while I am playing, but they are landing on the track about 120 ticks earlier than they should, universally. Then when I play back what I recorded, it sounds like a ****** retard just played the part. My timing is excellent on two instruments, it isn't ME. I have to play so outrageously behind the beat to get the notes to land where they should that it becomes nearly impossible to keep time.
But if I don't, they won't quantize properly because they are recording EARLY. Somebody has to be having this problem besides me. Damn this software.
This happens with every VI I have tried from boom to mini grand.
Veni, Vidi, Funki - I came, I saw, I laid the stank down
System 1: Retina MBP 512SSD/16RAM - Thunderbolt HDX1/HDIO
System 2: Mac Mini - 512SSD/8RAM - Thunderbolt HDX1/HDIO
OSX 10.8.5
Pro Tools 10 HD
Pro Tools 11 HD
SYNC HD
Old 01-30-2014, 04:17 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Manually played MIDI Notes arrive earlier than played.
I don't have the answer, but have you tried different routing to to see if there's a difference. are you recording midi onto an instrument track? have you tried a dedicated midi track routed to an instrument track and how about having the VI on an audio track and using a midi track etc.
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-30-2014, 05:26 AM
ChuckS ChuckS is offline
Maybe check/toggle the MIDI delay compensation options in Preferences . . .
PT 2020.5 DP 10.11 VEP 7.x MOTU M4 HP Envy 8G i7 Quad Laptop Win10 (x64 20H2)
PT 2020.5 DP 10.11 VEP 7.x 828mkII ADA8200 MTP-AV 2011 Mac Mini i7 Quad High Sierra.6
Old 01-29-2016, 12:15 AM
Chris Pettifer Chris Pettifer is offline
Hi there, I'm having the exact same problem now with PT 11. Did you solve it? It's so weird.
Regards, Chris
Old 10-06-2016, 12:38 AM
chickzen chickzen is offline
Oooooh YES YES,I have same problem from protools7....... after record VI, I have to manually move the MIDI note.........
Old 10-06-2018, 08:48 AM
galgalon96 galgalon96 is offline
Hey guys,
Have the same problem in PT 2018
Any solution?
Old 10-15-2019, 04:57 AM
XJENSEN XJENSEN is offline
For reference: This bug still seems to exist in 2019.6...
Old 10-16-2019, 06:47 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Hi all
Has anyone tried in PT’s preferences>midi tab enter in midi tick offset?
Plus or minus
OP said 120 ticks early so enter +120 ticks
T
(Help us Help You)<<<click here
APFS 90% 10% Audio on Both.
Pro Tools U-2020.5 macOS 10.14.6 APFS
Second boot-macOS 10.13.6 (Avid HDX-1 Omni)
(2k10MP 5,1 / 64-Gb)
(Sapphire RX-580 MVC-Edition-dual mini 6 pin. one spliced to add Avid mini 4 pin-hdx)
FW-CoreAudio (for poly-recording)
(SSL-HUI-MIDIoverIP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
new systems builds / upkeep / +
New builds:
12 core nMP HDX 1 Slot 5 stock HDX Mac mini 6pin to 4 pin HDX power like 5,1 mp's used)
16 core nMP rack-test station
28 just because machine
Wrong Notes played with midi controler 12bbb macOS 13 08-10-2015 01:10 PM
Can you see MIDI notes that are being played in PT11? ianbee Windows 6 09-15-2013 08:55 PM
Can't hear MIDI notes played via Instrument mirovaz macOS 2 02-07-2013 10:53 AM
Notes played in Midi Editor Nullifer Pro Tools M-Powered (Win) 2 04-01-2011 02:04 PM
Some midi notes are not played in instrument tracks Patill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 12-11-2009 09:53 AM
