#21
Re: Track Presets
QuicKeys is still my choice for these things. Thanks
Pro Tools Tutorials: Mixing Heavy Rock & Metal Pro Tools 11 - Tips and Tricks Delay Explained Tracking Rock - Drums Mixing Rock Music Production with Pro Tools Pro Tools Tips and Tricks Vol. 2 Pro Tools Tips and Tricks Vol. 3 Elastic Audio in Action |
#22
Re: Track Presets
Here's a little demo movie of me entering a shortcut and adding a track preset called "Voiceover" to my empty session. It merely takes half a second. |
#23
Re: Track Presets
Hey Oliver... where should I go about researching how to AppleScript for Pro Tools? I am using filemaker for spotting notes (on film) and would love to be able to applescript a selection and capture the start/end timecode and have it entered into my filemaker database.
Thanks for any advice you can offer! |
#24
Re: Track Presets
Oliver |
#25
Re: Track Presets
Making the presets might take a bit longer but we'd only be doing that once. Thanks
#26
Re: Track Presets
#27
Re: Track Presets
I am done with it and I tested it on 3 Macs.
It requires PT 11.1 and OS X 10.8.4, which is the minimum requirement. I developed it on Mavericks though. PT 11.0 - 11.0.3 is not supported due to major AppleScript flaws in those versions. In theory PT 10 support could be accomplished but I do not feel like supporting older PT versions right now. Everyone who's interested to test this can send me a private message. The plan is to release it in January. To sum it up: You get an installer which installs an Automator Action, Service and a CLI tool to enable the Notification Center support. After you installed the stuff, you will see the Automator Service appear in the Pro Tools menu under "Services". You then can assign a shortcut to this Service via System Preferences/Keyboard/Shortcuts/Services. Oliver |
#28
Re: Track Presets
I finally got around to using Kenny's method for setting up track presets with PTHD 11.1.1 and Windows 8.1. There are actually 2 places in Windows where you will find the folder "Session Templates". I found the wrong one first.
The one you Do Not want to use as the key for making your Track Presets folder is C:\Program Files\Avid\Pro Tools\Factory Content\Session Templates. The one you Do want to use is in ~Documents\Pro Tools\Session Templates (where ~ stands for C:\Program Files\Users\"Your Name"\). This correct Documents folder should show up by just opening Explorer. While both locations will ultimately work, the one you do not want to use will require you to shut down PT every time you save a track preset - PT writes whatever you put into the wrong folder into the right folder every time you start/stop PT. Using the correct file folder allows you to save and use the presets without leaving PT as Kenny shows in his video. Thanks for the video Kenny. Track Presets is truly a great time saver. Hope this may help someone. Greg
Protools PC, i9 10990, Gigabyte X299 mobo, 64 GB ram, EVGA Nvidea GT 720 TI video card, Win 10 Pro, PT Ultimate (Native) 2024.3.1, HD Omni, HD I/O 16x16 . |
#29
Re: Track Presets
Thanks for adding the Windows info.
#30
Re: Track Presets
Perhaps someone might have a solid answer for this. I've recently done a system restore. Prior to this all of my presets worked perfectly. I downgraded to 11.0.2 which resolved most of the problems that were occurring with track presets except for this: When I open a track preset the input routing is greyed out.
Its not too much hassle to set them back to what they should be but this wasn't a problem that I encountered before. It would be great if someone has a solution! btw if anybody cares. DO NOT UPGRADE TO 11.1.2 if you use track presets. Lots of crashing and the routing goes completely awry. |
Track Presets in Pro Tools 10 | albee1952 | Tips & Tricks | 33 | 05-06-2014 12:42 PM |
EQ Presets for Vocal Less Track | Becharax | Pro Tools 11 | 9 | 08-26-2013 03:46 PM |
Track presets in 11? | albee1952 | Pro Tools 11 | 2 | 06-24-2013 05:37 PM |
Track Presets!!! | albee1952 | Pro Tools 10 | 8 | 12-29-2012 09:13 PM |
Track presets in PT??? | dgkenney | Pro Tools TDM Systems (Win) | 3 | 12-22-2009 11:03 AM |
