Old 11-26-2013, 09:28 PM
jaminjamesp jaminjamesp is offline
Default Pro Tools 11 Shutting Down When I Try To Save
I know I'm supposed to put an error message in the title line, but I'm not getting one.
Every time I try to save my session, it just quits on me. And several times after try to save a copy in, and then just randomly. No message, no spinning wheel, just shuts down. I did a completely clean install two days ago on a brand new, clean system SSD. It's a Samsun 840 Pro. My session is running off a brand new LaCie 1TB thunderbolt drive. I don't have much on my computer right now.
I've tried restarting and deleting PT preferences. Not helping.
I'm running a mid 2011 iMac 2.7GHz. Mountain Lion. 24GB of ram.
I noticed it really got bad when I started running Komplete 9 Ultimate.
I'm recording to the same drive my samples are stored on, could that be a problem? probably so.
I have a second internal drive, the one that came with my computer. I cloned it to my external drive. Haven't reformatted it yet to record onto, so thats why I'm recording to my external.
Any ideas of what might be causing this??
Old 11-26-2013, 09:41 PM
mhmh mhmh is offline
Default Re: Pro Tools 11 Shutting Down When I Try To Save
In this thread a similar problem is discussed.
http://duc.avid.com/showthread.php?t=346597
What version of 11? Mountain Lion 10.8.4 or 10.8.5?
What happens with your CPU-Usage Meter while you save?
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0
http://www.pelhamundhaas.de/index2.html
http://www.pelhamundhaas.de/vita.html
www.3-p.de
www.imglashaus.de
Old 11-26-2013, 10:03 PM
no, thats not a similar problem. It could just be sitting there, no playback, and I'd hit apple s and it would crash. or even if i went to file>save it would crash.
now I have bigger problems. I was finally able to save a copy. I saved it to the same external drive. I opened it, made sure it worked then closed it. Then I went ahead and cleaned up my external drive, leaving only that file. I then went and reformatted the 2nd internal drive on my computer, so I could start recording to that. Now when I try to open my saved copy, I get a message that says the file cannot be opened because the alias is missing. 2 weeks of work gone. I'm running some data recovery software on my external drive in hopes that I can salvage the old session. 5 hours left on the scan of the disk. Lets hope something good happens.
I'm literally in full blown panic mode right now.
Old 11-26-2013, 11:52 PM
PMF Media PMF Media is offline
What about your "Session Files Backup" folder stored within your root session folder along with the "Audio Files" folder and the session itself, is PT saving these backups automatically? if so, sort by date and open the last saved and see how you go.
Pro Tools keeps shutting down Mbox2 Strebor24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 09-06-2009 03:00 PM
Pro Tools LE 7.0 shutting down after I hit a key on the keyboard colombianmike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-15-2008 10:44 AM
Pro Tools Keeps shutting down meshuggahmath 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-26-2007 08:57 PM
Kontact 2 with Pro Tools Shutting down jeroddumas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 04-29-2005 04:39 AM
Problems shutting down Pro Tools Eduardo Apolonia Pro Tools TDM Systems (Win) 6 03-27-2001 04:34 PM
