Old 11-10-2013, 05:23 PM
shameusf shameusf is offline
Default Best Way to Bounce/Create Mixdown
Hi all,
I have, what I'm sure is a very simple and obvious problem. I'm finishing off a two year recording project over the next few days and will be sending it shortly to a good friend and professional engineer for his opinions on the fruits of my labours.
Can anyone tell me what the best way is to send these to him from my existing Protools 11 sessions? Should I be bouncing to disc, or creating some kind of master mixdown version of my tracks? And what is the best file format (using Protools 11) for this?
I remember 'back in the day' bouncing to disc as a different file format. Is that still the best way? I've also seen people use different ways of creating a superior audio master file.
Cheers muchly in advance. The back end of the recording process really isn't my area of expertise.
Old 11-10-2013, 05:26 PM
Default Re: Best Way to Bounce/Create Mixdown
Originally Posted by shameusf View Post
Hi all,
Ask your good friend and professional engineer exactly what he wants and in exactly what format.
Old 11-10-2013, 06:08 PM
Southsidemusic's Avatar
Hi
If you want your friend to listen and make notes on your work I would think an MP3 bouce file of each song would be enough. You could bounce down to WAV if you want a higher bitrate and better sound for mastering but I doubt he will critique your sound quality on an MP3 if he isn't gonna make any changes or matering work on the project. And WAV files of each song would be a lot bigger size wise too so I would do MP3 bounces of each song.
Make sure all the levels and Master track is good and not peaking in the hard yellow when you bounce. In PT11 it takes a second per song so do a few tests and make sure everything is A-OK before you commit.
When you bounce just mark the whole song from start to finish and start the ounce. If you don't mark the exact song the bounce will continue as long as your harddrive can take it so be very careful and exact in marking the start of each song and ghe end of each song. You can leave a bar or a half of a bar in the end but the bouce should be exacly from start point of the song.
Goto bouce to disc and make sure the settings for "interleaved" is checked so when you bounce a stereo file it comes out as one file and not two (L and R) files. Good luck with the project and if you have invested 2 yrs I hope it pays off somehow for you
PS. The older file extensions you mentioned in "bounces" you probably were thinking AIFF files but they won't play on most portable or stationary players like iphones ipads and equipment that plays normal MP3 and WAV tracks.
Best of Luck
Christopher
Best Regards
Christopher
South Side Music Group
WEBHOME
SOUTHSIDEPUB
#ninjakittenshatecrunchyleaves
Eagles may soar, but weasels don't get sucked into jet engines
Instruments fade out in mixdown or bounce neilbenezra Virtual Instruments 0 10-08-2010 01:46 PM
Must you BOUNCE to create a wav file? Mark Adams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-03-2007 06:55 AM
Bounce (mixdown) stops due to cpu overload Eli V/d Vondel Pro Tools M-Powered (Win) 1 01-29-2007 06:37 AM
5.1 Mixdown to Stereo Bounce stealth_162 Post - Surround - Video 11 02-04-2006 02:08 PM
Mixdown(Bounce) Long Sessions James Harrington 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-23-2002 08:22 AM
