Old 11-02-2013, 05:56 PM
mesaone mesaone is offline
Default TC/E still missing in 11.0.2? [SOLVED]
I just upgraded from 11.0.1 to 11.0.2 today.
TC/E is missing still, I thought it was supposed to be added in. It's still there in 10.3.6.
Old 11-02-2013, 06:07 PM
Meads Meads is offline
Default Re: TC/E still missing in 11.0.2?
Where are you looking for it?
It's definitely there.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 11-02-2013, 06:14 PM
setup>preferences>processing
http://i.imgur.com/Yc8nAPK.png
Old 11-02-2013, 06:20 PM
Well, that's weird...
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 11-02-2013, 06:37 PM
Yeah, it is. Disappointing. I did a full uninstall of 10.3.6 and 11.0.1. Then I restarted, installed 11.0.2 and then 10.3.7.
Then I restarted, and presto, missing TC/E.
Old 11-02-2013, 06:58 PM
I wonder if this fatal error has anything to do with it.
http://i.imgur.com/wZrkitN.png
It's nice to know that even incremental updates can prove fatal. Good thing I was stupid enough to attempt a minor update today, so I can maximize my frustration before my next session.
Old 11-02-2013, 07:54 PM
Gems Records Gems Records is offline
same problem with t/ce last week
clean install fixed it
Intel i7 930 2.8ghz, dual 500gig raid 0, 1 tb audio drive, ati radeon 5560, M-Audio Projectmix io, Motu 896 HD through adat
Old 11-02-2013, 07:57 PM
I hope that'll do it. I did a clean install of 10.3.7 and 11.0.2. No dice. Wiped everything including MBOX drivers, working on the second clean install right now.
Old 11-03-2013, 05:08 AM
txshonk txshonk is offline
EDIT - 3rd install did the trick but I had make sure I uninstalled preferences and database.
I am not using PT11 regularly yet, but my main install of PT11 doesn't show TC/E either. I have also done a fresh install with 11.0.2.
I hope Avid figures the issue out so their full feature set installs consistently before I make the switch formally. 11.2 maybe?
Dave
Old 11-03-2013, 03:57 PM
Yeah, got it working. Wiped everything pro tools - related. Avid effects, 10.3.7 and 11, etc.
Wiped prefs, volumes, database. Reboot, tried a clean install for a third time. This time around I installed 10.3.7 before 11. Then it worked. No fatal errors, no missing bits and pieces. TCE is so much better than Timeshift, so I'm glad I got it straightened out.
Altogether a painful experience, but most likely user error to begin with.
ProTools HD 10.3.6 - iZotope RX3 DlgDenoiser 'missing plugin' isn't missing paranerd Pro Tools HDX & HD Native Systems (Mac) 4 10-03-2013 07:39 AM
1 band EQ settings missing and Xpand missing? rockguitarist1255 Pro Tools 10 5 02-19-2012 04:33 PM
Missing fade files, missing audio in resaved sesssions drygruo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-14-2010 04:56 PM
Pro tools says Files Missing but they're NOT missing.... nealobrien 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-13-2008 06:09 PM
missing audio files are actually not missing tomcat Pro Tools TDM Systems (Mac) 3 12-24-2006 02:25 PM
