Old 10-22-2013, 12:23 PM
clausiii's Avatar
clausiii clausiii is offline
Default Mavericks
So, any early adopters out there ? :-D
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 8GB RAM
ProTools 2018.3
MacOS High Sierra
MOTU 4pre
Axiom Pro 25
tons of stomp boxes
tube amps
guitars
noise
Old 10-22-2013, 12:34 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Mavericks
There are already some known issues with 10.9
http://avid.force.com/pkb/articles/t...Tools-Sibelius
Keep that in mind before you update.
Brian
Windows 10 Pro 64 Bit
Pro Tools 2018 | Eleven Rack + ERXP
Youtube Channel - BenoniStudio
Free Eleven Rack Tutorials, Rigs, and more
@BenoniStudio
Instagram
Old 10-22-2013, 12:49 PM
jbrown7282 jbrown7282 is offline
Installing now on an alternate system, Keeping the Avid KB in mind I will see what other software it affects...
Old 10-22-2013, 02:01 PM
Bob Olhsson Bob Olhsson is offline
The uninstaller issues look pretty daunting. This one sure has that "prepare to upgrade absolutely everything" vibe to it.
Bob's room 615 562-4346
Georgetown Masters 615 254-3233
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 10-22-2013, 02:44 PM
CME CME is offline
I'm going to give it a go on a back up HDD. Just to see what it does. I may also try it on my MacBook as it rarely sees any audio use these days anyways.
And the only known issues are uninstallers don't work? Seems as though that could be a fairly simple and quick fix. I'm sure avid can have it done before 2015.
2009 Mac Pro - Dual X5650 Xeon 6-core 2.66Ghz procs, 48GB of Ram, SATA 3 and USB 3.0 PCIe cards. R9 280X video card. macOS Sierra. Harrison Mixbus 32C, Studio One 3, Reaper, and pro tools 12 when I have to.
Old 10-22-2013, 02:50 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
And -6101 errors, which also seem to be a problem for 10.8.5 users.
I'll make some popcorn from 10.8.4.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 10-22-2013, 03:29 PM
propower propower is offline
Be a Maverick --- try Mavericks -- couldn't resist
2017 27" iMac 3.8GHz i5, 1TB SSD, MC Mix+Control
Logic ProX, Studio One V3, PT12.8 Orion Studio 2017, Zen Tour, Dangerous Source
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
Old 10-22-2013, 03:33 PM
RyanC RyanC is offline
Put it on my clone-
Both 10.3.7 and 11 are running MUCH better at low latencies. I have a big session open in 11 that would not play without at 9172a @ 32 buffer on 10.8.4, It's playing glitch free @ 88% (@32 buffer) while I'm typing this.
Hoping 11 will also be more stable in 10.9, wont really be able to tell that right away. But so far it's definitely running better than 10.8.4 was.
Old 10-22-2013, 04:34 PM
mattrixx mattrixx is offline
I've been running it on 10.9 for quite sometime. It certainly didn't work on early dev versions, but has been running fine for me on my second machine for a couple of months. YMMV.
If you are going to dip your toes in the water, make sure you have backups!
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
Old 10-23-2013, 07:32 AM
CME CME is offline
I installed it on a secondary drive, forgot how slow 7200 rpm drives are. I even used to migration assistant or whatever it's called to move everything from 10.8. I didn't get to try much did try a session on pt 10.3.7 and it played back fine. I'll play with pt 11 a little later and see what happens.
PT 11, 002, and Mavericks mixshack Pro Tools Software (Mac) 7 03-15-2015 06:34 PM
Anyone using 11.1 with Mavericks 10.9.1? boxedin Pro Tools 11 3 12-30-2013 12:19 PM
OS x Mavericks and PT 9 Riky290 Pro Tools Software (Mac) 15 10-28-2013 03:09 PM
OS X Mavericks derFunkenstein Pro Tools Software (Mac) 8 10-09-2013 10:49 AM
