Old 10-08-2013, 01:41 AM
P_J P_J is offline
Default Clip indicators in edit window don't work
Clip indicators in edit window (or track list) don't work in 11. Clip indicators work only in mix window. Bug?
Old 10-16-2013, 11:06 PM
P_J P_J is offline
Default Re: Clip indicators in edit window
Anyone?
Old 10-16-2013, 11:57 PM
Shan's Avatar
Shan Shan is offline
You are correct. I'm seeing this also.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 10-17-2013, 03:04 PM
dave911's Avatar
dave911 dave911 is offline
Same here.
My master fader clip indicator does work in the edit window, but no others.
"In theory there is no difference between theory and practice. In practice there is." - Yogi Berra
Old 10-17-2013, 05:40 PM
dave911's Avatar
From the what's new.
Looks like the mix window shouldn't show clip most of the time. - hmmm
"Audio Track Clip Indicators
Audio track clip indicators display red under the
following circumstances:
• When an audio track is record enabled or set to
input monitoring and the input assignment is set
to a physical input signal that exceeds 0 dBFS
causing clipping at the converters.
• When an audio track is recording to a fixed-point
bit-depth (16- or 24-bit) and the audio written to
disk exceeds 0 dBFS causing clipping in the file."
show clip name in edit window browniespeaks Windows 2 05-11-2020 04:05 PM
edit window not showing clip on a meters dmitri85 Pro Tools 11 9 10-25-2014 03:03 PM
Edit window not in foreground when a clip is highlighted! Herokazz Windows 0 04-14-2012 08:57 AM
LED Clip Indicators - Different in PT8 than PT7.1? bugnut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-12-2011 04:05 AM
clip indicators Guruman Tips & Tricks 2 04-16-2002 12:56 AM
