Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 08-15-2013, 07:11 PM
mschaeffer mschaeffer is offline
Default How to transfer iLok licenses from old to new iLok
I have an older green mbox iLok with my Pro Tools 10 license on it. The pins from the usb connector to the board are coming loose and I can only get it working some of the time. Right now it is working and I can open Pro Tools, but I need to get the license onto my new iLok before the old one completely dies.
The iLok website says: "You can try to move licenses from the broken iLok back to your account or to another iLok when both iLoks are registered to your account. If your iLok connector is loose or broken and you can get the iLok to connect only some of the time, you should not try to move more than one license at a time."
I can not find any way in the new iLok license manager program that allows this. Both iLoks are plugged in and registered to my account. If I try to deactivate a license from the old iLok I get an error message that says "An unexpected error occurred."
Old 08-15-2013, 08:19 PM
sunburst79 sunburst79 is offline
Default Re: How to transfer iLok licenses from old to new iLok
The new method of moving licenses is drag and drop. You just drag the license you want to move from the main window on the right to the iLok you want it to move it to in the left hand pane.
At least that's how it worked for me.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 08-15-2013, 10:20 PM
Bruce Paine Bruce Paine is offline
Admin Emeritus
And if you have a problem with that method, you can try just having one iLok connected, and dragging the license to your account at the top left.
Then remove the old iLok, insert the new iLok, and drag the license from your account to that iLok.
You no longer have to only move a license from an iLok to an iLok, you can store it on your account. It's a little scary, because it says "you are about to deactivate a license", but you are simply removing the license activation from the iLok and moving it to your account.
Bruce Paine
System Details
Old 08-16-2013, 05:55 PM
Benoni's Avatar
Benoni Benoni is offline
Just wondering, when you are trying to deactivate a license, what method are you using? The buttons on the top right, file menu, right click, or drag and drop?
Also are you doing this from the Account view or are you choosing an iLok first, and then choosing the license?
In my experience, it works better to choose the iLok first and then the license. Instead of looking at all your license from your account and trying to activate/deactivate a license.
I don't know why, but I can reliably reproduce this problem at least with the Active button.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
iLOK broken, transfer license to good iLok question Jay Terrien Windows 12 09-18-2012 05:12 PM
[HELP] Can't Transfer ProTools10 Licence to My iLok (unDetect iLok) :( nmstudio Windows 5 10-25-2011 03:10 AM
how to transfer ilok registration with no ilok... AdamPT8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-02-2010 09:54 AM
Can You Transfer iLok Licenses To A New iLok If Your Old iLok Is Broken? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-07-2009 03:51 AM
Transfer iLok auth. from old iLok to new 003 factory iLok? lamp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-20-2007 07:05 PM
