Old 08-04-2013, 11:39 AM
bgeorge03 bgeorge03 is offline
Default Will I be install & run both Protools 11 trial and Protools MP 9 in same laptop
I will be installing Protools 11 trial version in my laptop which already has Protools MP9 installed. When I install the Protools 11 trial, Will it delete the Protools MP9 version from laptop? Will I be able to use both Protools 11 trial and Protools MP9 from the same laptop?
Old 08-04-2013, 11:45 AM
Default Re: Will I be install & run both Protools 11 trial and Protools MP 9 in same laptop
You cannot have MP 9 or a 9 full version and 11 coinstalled. Uninstall MP 9 before installing the 11 trial. You can/should clone your boot/system drive and use that clone for the trial and revert back to the pre-clone later if you need to. Either way always have a backup.
Pro Tools 10.3.6 and Pro Tools 11 can be coinstalled, but there was magic done in 10.3.6 to allow that.
Darryl
Old 08-04-2013, 11:52 AM
Thanks for your quick reply. If I purchase Protools 11, Will I be getting a free license & copy of Protools 10 too? I have few Pluggins in RTAS or AAX 32bit format like Native Instruments Elements which will not run in Protools 11 and I would like to use them. Hence I may be need to install both Protools 10 and Protools 11 till the Pluggin manufacturers release AAX 64bit versions.
Old 08-04-2013, 11:59 AM
Yes, Pro Tools 11 includes a Pro Tools 10 license.
Old 08-05-2013, 06:14 AM
I am running Protools MP9 on Intel Core i7 laptop with Windows 8, 8GB RAM, 1TB HDD 5400RPM. When I add compressor to audio track (Voice), it starts giving noise when playing the tracks. Should I need to upgrade the hard disk to 7200RPM to fix this issue? Will an upgrade to Protools 10 from Protools MP9 fix the issue?
Old 08-05-2013, 06:19 AM
JFreak's Avatar
JFreak JFreak is offline
Only two different PT versions that you can co-install are the latest 10.3 and any 11.x versions
Janne
ProTools 11 Trial version on Mac Mini sanjeevpunj Getting Started 1 02-12-2014 12:28 AM
ProTools 11.0.3 Trial Mac When? geoff.mix Pro Tools 11 2 01-12-2014 10:36 AM
new error when trying to install protools 6.9 on my laptop samuelowen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-06-2007 10:49 AM
PROTOOLS TRIAL ANYONE? Logicdance Pro Tools TDM Systems (Mac) 4 12-10-2006 02:32 AM
Protools M-Powered 30-day trial ericsmusic Pro Tools M-Powered (Mac) 1 02-14-2006 09:03 AM
