Old 07-27-2013, 12:46 AM
Firechild Firechild is offline
Default Is it possible to run TDM card as Core Audio in Pro Tools 11
Is it possible to run HD TDM as a core audio interface in Pro Tools 11 ?
I guess it works in Logic Pro X so why not in Pro Tools 11 ?
( will try in Logic when I´m back in the studio )
HD3 PCIe, HD I/O , HD10.3.10, Mac Pro 6 core , 24 GB RAM , GTX285 , 10.8.5 , UAD-2 Quad Satellite , ATC SCM25A Pro with ADAM Sub 12.
Old 07-27-2013, 01:06 AM
Mark Ziebarth Mark Ziebarth is offline
Default Re: Is it possible to run TDM card as Core Audio in Pro Tools 11
A nice idea but I bet it is not possible. And Avid/Digi are not well known for their excellent ASIO and Core Audio drivers...
Mark
Mac Pro Harpertown 2 x 2.8 GHz Quad Core, HD3 Accel (PCIe), 192 I/O, Sync I/O, Euphonix MC Control, Artist Mix and Pro Tools 10
iMac 2013, HD Native, HD Omni, Pro Tools 12 HD, Avid Dock with Avid Pro Tools Control
Old 07-27-2013, 01:11 AM
Running the core audio driver "Digidesign HW ( HD )" in the 64 bit app Logic Pro X without any trouble at all, even at the minimum supported ( with the Digidesign audicore driver ) 64 samples buffer size...!!!
The Digidesign HW driver is only 8 in/outs but hey it is working great !
How about Pro Tools 11 ?
Old 07-27-2013, 03:38 AM
BasketCase BasketCase is offline
As a semi related question...
If I upgrade my version of Protools HD to HD 10, can I then upgrade again to HD11? Or must you own a HDx or HDn card to do it? I realise my TDM cards won't work, but it might come in handy...
Old 07-27-2013, 03:44 AM
Chief Technician's Avatar
Arrow Re: Is it possible to run TDM card as Core Audio in Pro Tools 11
TDM hardware is not available as a CoreAudio device on a system that only has v11 installed.
Old 07-27-2013, 07:29 AM
Ok, but if you have a PT10 install prior PT11 it must be there, cant see any reason at all why it should not work if the driver shows up in Logic. I mean Core Audio is Core Audio..and you can use Core Audio in Pro Tools 11...
Old 07-27-2013, 07:57 AM
PT11 will not recognize a TDM card as a CoreAudio device. I do not know why this is the case. I just know that it is.
Old 07-28-2013, 04:06 AM
maxon maxon is offline
It's marketing issue not technical issue
RECORDING Studio: Mac Pro, OSX 10.6.8, PT HD 3 PCIe, Pro Tools 8.1.1,
MIX + MASTERING Room: MAC Pro, OSX 10.6.8, PT HD 3 PCIe, PT 8.1
3x 192 I/O, Digidesign PRE, UAD Octo, UAD Satellite Ultimate
Old 07-28-2013, 06:12 AM
Maybe... howerever a workaround can be to create a Aggregate audio device in OS X Audio MIDI settings...using the TDM audio core driver...
Old 07-28-2013, 02:41 PM
Avid does not like customers, who wants to run PT11 on HD cards and trying to use VST plugins
Pro Tools HDX Card and Core Audio neckarklangwerke Pro Tools 10 0 11-08-2011 04:21 AM
Delayed Quicktime playback through Core Audio Card Dennis Scott Pro Tools TDM Systems (Mac) 0 04-11-2010 08:43 PM
MIX core card as audio host in 10.3.2 dancoleman Pro Tools TDM Systems (Mac) 1 03-11-2004 09:03 PM
882 1/0 audio interface with mix core card pmurf Pro Tools TDM Systems (Win) 1 02-24-2004 11:00 AM
osx core audio driver and d24 card lovespirals Pro Tools TDM Systems (Mac) 3 09-20-2003 01:42 PM
