Avid @ NAMM 2018
Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 11 Discussion
Old 07-26-2013, 12:28 PM
dts350z dts350z is offline
Default PT 11 Rewire bug
I'm posting this for the developers at plogue.com
this is a major bug with Pro Tools 11. ReWire devices are only scanned when the DigiReWire plugin is scanned (which typically happens when running a new Pro Tools version). Any ReWire device installed after that scan will never show up in Pro Tools 11 until a new plugin scan occurs.
On OS X this can be forced by manually deleting the file name InstalledAAXPlugIns
in <your user>/Library/Preferences/Avid/Pro Tools
If the issue also occurs on Windows, there is most likely a similar file.
Someone should report this to Avid
From: http://www.plogue.com/phpBB3/viewtop...p=35801#p35801
Old 07-27-2013, 03:36 AM
Chief Technician's Avatar
Lightbulb Re: PT 11 Rewire bug
Please post this at protools.ideascale.com. That is Avid's preferred forum for tracking bugs.
Old 07-27-2013, 05:35 AM
Jay_uk Jay_uk is offline
Default Re: PT 11 Rewire bug
And there was me thinking it was for ideas...
Old 01-16-2014, 05:51 PM
phydaux2000 phydaux2000 is offline
Thanks for your informative article, unfortunately I can't find the InstalledAAXPlugIns file anywhere on my computer, I'm running Maverics 10.9.1 Pro Tools 11 and Reason 7 in 64 bit mode. I've looked for similar files in all my librarys to no avail. Thanks
Old 01-18-2014, 09:57 AM
d1000 d1000 is offline
Hi phydaux
The file should be in the Library folder in your Users folder (your Home folder), not the one in the root folder.
Make sure that that Library folder is visible (by default it's not)
See this article for more info on making the user library folder visible:
http://www.macworld.com/article/2057...mavericks.html
Hope this helps - I just fixed this on my MBP.
OSX 10.9, PT 11.1.1, Reason 7.0.1
Btw. OSX 10.9.1 is not supported yet - of course, it might work, but still.
See this article:
http://avid.force.com/pkb/articles/e...oductCategory=
Kind regards
dan
Old 02-17-2014, 09:41 PM
hybernation hybernation is offline
Thank you dan!
Old 02-17-2014, 10:03 PM
crandallwarren crandallwarren is offline
On windows 7, the file is here:
C:\Users\Studio A\AppData\Roaming\Avid\Pro Tools
Had to do the same to get Reaper to show up as rewire slave
Old 02-25-2014, 12:14 PM
nicklusk nicklusk is offline
Thanks for the info, one side note that I got stuck on.
When you select view options in finder, you have to be in your macintosh HD>Users>"Your username" folder already for the "show library folder" option to show up.
Thanks again
Old 04-17-2014, 06:12 AM
Fabulous Fabulous is offline
I deleted the file and it made no difference. Still not rewire for ableton 9
Old 11-28-2014, 11:47 PM
b mcgibney b mcgibney is offline
Did you ever resolve this? I am having the same lack of rewire problems with Reason
MacPro 3,1 dual Quad-core 2.8. OS 10.6.8. and 10.8.5 and a MAC PRO 5,1 dual six core 2.93 . RME FF800 and a bunch of noisemaking gear
Rewire quit unexpectedly but pro-tools still thinks rewire.. rustybucket 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-17-2007 07:57 PM
ReWire? sykobilly65 Pro Tools M-Powered (Win) 1 10-03-2005 08:55 PM
Rewire star one 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-29-2005 05:54 AM
FXpansion - Rewire - VST to RTAS or VST to Rewire Sweet Lou P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-01-2004 10:38 AM
Where do I get Rewire? Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-13-2003 12:50 AM
