Avid @ NAMM 2018
Old 07-24-2013, 07:29 AM
Jonnyb27 Jonnyb27 is offline
Default Mbox 2 on Mac OS X 10.9 (Mavericks)
I'm testing the new OsX 10.9 (Developer Preview beta 4) with Logic X with a Mbox 2
I guess Mbox2 mini is unsupported, I've tried to use it as main audio device with several softwares, Itunes, Djay, Logic X...
The device is recognized by the Mac, and the System Configuration, Logic automatically find it and the device appears as usual but not sound come out from it. Just a rhythmic click that fades in and out, it's the same with any audio software.
Any one as suggestions? Maybe was the same with previous OS X versions.
I don't know, if someone can help or suggest please reply.
Thanx
Jonny
Old 07-24-2013, 01:05 PM
kurt's Avatar
kurt kurt is offline
Default Re: Mbox 2 on Mac OS X 10.9 (Mavericks)
So how is Mavericks?
..Have you got & installed the latest drivers for the mBox?
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5
PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear.
http://www.mmvstudios.com
Old 07-24-2013, 03:31 PM
Of course I've Installed 10.3.3 drivers.
Maverick works fine, pretty cool stable and the RAM is managed very well.
It's got some innovations in the finder and the web browsing on safari is really immediate.
All the old software I've have installed before is running perfectly.
But..
I' don't know why my Mbox2 mini does not puts out any sound (except for a crackling click) , even if the system recognizes immediately it...
If anyone as got some ideas about this problem solving just reply...
thanx
Old 07-25-2013, 03:21 AM
well, I've got an update:
- the Mbox2 mini records the sound as well. Input channels are working and the Logic X records as usual the sounds from mic or line.
- The sound monitoring works but only inside the device, with headphones or speakers.
- I can record the sounds but I can't hear what I've recorded via Mbox2 mini.
So I must use the built-in sound card for listening.
Anyone knows how to fix this problem?
thank you very much
Jon
Old 09-15-2013, 02:54 PM
anyone tested mbox2 mini with Os X 10.9 ?!?
Old 10-23-2013, 08:39 AM
protoolsfanatic protoolsfanatic is offline
hello, i use pro tools 8.x le and mbox mini 2
i just updated to mavericks.. my mbox starts.. but no sound is playing :-(
Old 10-23-2013, 12:42 PM
RangioftheLight RangioftheLight is offline
I've upgraded my 2008 macbook pro to mavericks, was told after upgrade that pro tools was incompatible (I'm running LE 8.0.5). Checked the "incompatible software" and found the digidesign midi plugin and the mbox2 plugin files there.
Reinstalled the mbox 2 driver (v90_69594) and hey-presto! Pro Tools LE8 running fine, MBox 2 Micro running fine, other audio sources playback through the mbox micro... haven't yet tried recording audio or midi with my fullsize MBox2 yet, will try later today.
Old 10-23-2013, 04:20 PM
bnote bnote is offline
I have Mavericks running on my macbook pro. My mbox 2 mini gets powered and is recognized under my sound settings but no output. Alls i get is a loud static in my monitor and no sound at all in my headphones. Im using Pro Tools Le 8.0.5 pro tools opens up and i hit play it seemed to be working just no sound. I have 3 digidesign plug ins in my incompatible software folder. Firewire midi, Mbox2 midi and Midi Driver.
Old 10-24-2013, 02:03 AM
i use pro tools le 8.0.4. with mbox mini 2. pro tools works fine but NO sound. i reinstalled the drivers but still the same problem. i also tried to install mbox 2 drivers but still same.
Old 10-24-2013, 02:54 AM
Continuing from my post earlier, I've tested my Mavericks installed Macbook pro with the Mbox 2, and no problems whatsoever! Playback is fine and smooth, no plugin errors. Pro Tools LE 8.0.5 records audio and midi just as well as it did with Mountain lion. Happy! Hope everyone else gets to the same point. My experience is definitely evidence for compatibility.
Mbox 2 Pro with Mavericks 10.9.2 iang77 FireWire and USB Audio Interfaces (Mac) 8 07-22-2014 01:41 PM
Mbox 2 and Mavericks 10.9.1? formento FireWire and USB Audio Interfaces (Mac) 4 04-10-2014 09:37 PM
Mbox and OSX Mavericks seeeker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 03-24-2014 03:57 PM
Mbox 2 and Mavericks 10.9.1? formento FireWire and USB Audio Interfaces (Win) 1 02-04-2014 08:26 AM
Mbox 2 & Mac OS X Mavericks 10.9 Jay_Red27q 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-28-2013 09:44 AM
