Old 06-24-2013, 11:34 AM
sares sares is offline
Default 003 driver problem pt11
My 003 in PT 11 Shows like Asio003 Firewire.
I Need that my 003 shows an operate like they are originally: A Digi003 (without asio in PT.
Help Me!
Old 06-24-2013, 11:50 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: 003 driver problem pt11
Can you select the AVID 003 as the audio engine? Did you download the newest 220/003 drivers?
The newest drivers say "Avid" and not "Digi" in the engine dialog.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 06-24-2013, 12:17 PM
I think Park is all over this one. Ever since 9, the driver is a separate download and install. Grab the latest driver and things should get better(but you probably still need to open the Setup>Hardware menu and select the 003 as your audio engine). Holding the N key while opening Pro Tools will take you directly to that window.
Asus x99, Intel i7 6800K, 32 gig DDR4, GeForce 750 Ti, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs and Midas..............................
www.capricornsoundworks.com
Old 06-24-2013, 12:30 PM
I Have the 9.0.3 driver.
Avid shows to download a 9.07 driver with "support" to PT11
BUT DONT WORK!!! AFTER INSTALL 9.0.7 driver NOT APPEAR THE UPDATE IN MY w7 device manager the driver after install 9.0 7 still appear the 9.0.3
Curiosly the 9.0.3 have a 16mb of size and 9.0.7 have a 8mb of size.
I´m suspect that the new driver are corrupted
Avid:
Old 06-24-2013, 01:13 PM
I guess you are on a PC. The Windows driver is version 9.0.7. Mac is 11.0.0.
http://avid.force.com/pkb/articles/d...02-003-Drivers
I am on a Mac so I don't know about the PC driver version. Perhaps someone else can report on the success or failure of that driver.
When you boot into PT10, does it work there?
Park
Old 06-24-2013, 01:15 PM
Yes
PT 10.3.6 Work correctly
Old 06-28-2013, 08:58 AM
nigelpry's Avatar
nigelpry nigelpry is offline
So, experimenting with the new V11 003 driver on a Mac, and various audio software apps, including PT10.3.6, PT 11.0.0, Logic 9.1.8, Cubase 7.0.3, Wavelab 8.0, Harrison Mixbus 2.3 etc etc
Using a 003 Console (not rack), and choosing 'Avid 003' as the audio interface.
First off, 003 seems to be working well in PT11, all buttons, dials, faders and knobs seem to be working as usual.
In PT10, the 003 now acts as an audio interface, but the console no longer controls Pro Tools. In effect, it acts the same in Pro Tools 10 as it always has done with every other app.
I guess, from this, that when selecting 'Avid 003' in the hardware select box, I'm now selecting its Core Audio Driver, just like I do for other apps.
Also, the previous core audio manager no longer works, it does not detect the 003 with the new driver. Instead, there is a new 003 manager which resides as a utility in system preferences. It does all the same things as the previous core audio manager, but does not automatically open when an app accesses the 003.
There's one noticeable difference though. Whereas with the previous driver, when not using Pro Tools, you got a helpful bit of text in the LCD Display, which either said 'Offline' if nothing was accessing the device, or 'Working' if something was accessing it, now the LCD screen remains blank at all times, except when running Pro Tools 11. That's a shame, as it was a useful bit of info to have visible.
The good news is that, having selected 'Avid 003' as the device. and without any other messing about, all my other DAWs seem to be accessing the audio interface part of the 003 reliably. I can switch from one to the other, switch into and out of either pro tools versions, and there are no issues so far.
However, the lack of PT10 console support is a complete disaster. I'm not surprised its not working, as the driver download page says as much, but its nevertheless a big issue.
Does anyone (Avid?) know, and if so can they say, whether the lack of PT10 support is a temporary thing? Will there be a subsequent driver version released that supports both versions?
It means that, for now, co-install and switching between PT10 and PT11 is a big deal. It's a case of uninstalling the current driver, rebooting, installing the other driver, and rebooting again, if I still want to use the console controls when switching from 10 to 11 or vice versa.
So much so, that, for now, I will be uninstalling the 11 trial, as I use my console controls and need to have a working PT10 installation, given the lack of AAX2 plugins so far. It's a pain, as this means I'm not going to be able to test drive PT11 properly ... my trial days will carry on counting down regardless.
Oh well, at least, for me, this kicks that final decision about upgrading CPTK to HD off into the long grass. PT11 is not really viable for me unless and until all my essential plugins are AAX2 ready.
Mac Pro 2009 12-Core 3.46ghz, 64gb RAM, Macbook Pro 2011 17", 2.2ghz i7, 16gb RAM both OSX10.12.6
Dig 003 Console, MBox 2 Pro and Micro, MOTU 2408mk3, 2x 24 i/o and Traveler, UAD Apollo Quad, Apollo Twin mk11, pci-e Octo and Satelite Quad, Adam A77X monitors.
PT12.8.3, Media Composer 8.9.1, Sibelius 8.5.1, Cubase Pro 9.0.30, Logic Pro X 10.3.3, Wavelab Pro 9.0.35.
Various apps, soft synths, FX plugins.
Plenty of hardware synths, rack gear, microphones etc.
And then there's the studio ;-)
Old 06-28-2013, 02:55 PM
For a PC with 003, I recommend removing ASIO4ALL. On my rig, nothing worked correctly with ASIO4ALL on the system. As soon as I removed it, the 003 worked perfectly(and still does today)
Old 07-03-2013, 08:56 AM
mbat4100 mbat4100 is offline
After a week of iLok licensing problems I have just done CPTK crossgrade and now I am having same problem with 003 with upgrade to 10.3.6
Haven't even got to installing the PT11.
Installed latest 002-003 family driver 11.0 and 10.3.6 and now my 003 only acts as an interface.
Like other users this a complete disaster and must be a mistake.
Any advice from Avid please what to do ? Or what will be done about it?
I made enquiries BEFORE I upgraded and was assured the 003 would work. I assumed that meant with PT10 as well as PT11 given that there was nothing wrong with my PT10/003 system until the upgrade. Certainly that was the implication.
Old 07-03-2013, 09:03 AM
As a postscript: This can't be a hardware problem as the 003 worked fine with PT10 before the software/driver upgrade .
It is a few lines of code that someone urgently needs to write to fix the problem surely!
correct driver version for 003 with PT11.1.2 on OSX 10.8.5 altavek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-05-2014 02:14 PM
correct driver version for 003 with PT11 on OSX 10.8.5 altavek FireWire and USB Audio Interfaces (Mac) 0 02-17-2014 11:39 AM
How to start PT11.1 without Audio driver in Win 7? peterle Pro Tools Software (Win) 2 01-01-2014 12:20 PM
003 OSX Driver for PT11/10.3.X Simultaneous Use Arya44 Pro Tools 11 2 10-04-2013 10:31 AM
HD1+192 Core Audio Driver Non-HD PT11? zoundman Pro Tools TDM Systems (Mac) 0 10-23-2011 07:48 PM
