Go Back   Avid Pro Audio Community > Legacy Products > RTAS & TDM Plug-ins
Old 06-21-2013, 06:31 AM
rantanplan rantanplan is offline
Default MD3 and Brickwall Limiter - How to prevent bus clipping?
Hi there
When I use MD3 and Brickwall Limiter one after another on a bus, I have to lower the output of the MD3 and add gain again at the limiter input stage. Otherwise the bus gets overloaded. But this approach reduces the resolution - is there a better way to daisy-chain these plugins?
Or is the Pro Tools bus so high-resolution that it doesn't matter when the MD3 is driven less "hot"?
I'm using PT 8.1.1 on HD 3 Accel
Old 07-04-2013, 04:22 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: MD3 and Brickwall Limiter - How to prevent bus clipping?
Originally Posted by rantanplan View Post
Hi there
Any plugin will have to have a level of at least -0.1db or ideally -0.2db below -0dbfs when feeding another plugin or going out of a channel or aux. providing you do this nothing should peak or clip etc.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Problem With TC Brickwall Limiter II TDM Alécio Costa Pro Tools TDM Systems (Mac) 3 04-20-2012 02:50 PM
Cut Only EQ clipping light after brickwall limiter on Master Fader? spiritG Pro Tools TDM Systems (Mac) 5 08-24-2010 08:18 AM
Brickwall Limiter - Shootout mikevarela Post - Surround - Video 0 03-24-2010 04:45 PM
Mastering_Looking for the Best Brickwall Limiter c.evans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-22-2007 10:14 AM
Oxford Limiter vs TC brickwall limiter stargazer Pro Tools TDM Systems (Mac) 3 04-28-2006 12:32 PM
