Old 05-25-2013, 11:52 PM
kudca kudca is offline
Default Not enough ASIO output channels available.at least 2 channels are needed.
Not enough ASIO output channels available.At least 2 channels are needed.
This pops up when i enter my Audio settings in fl studio and go to Avid Mbox ASIO under my ASIO Devices. This started happening today.I can't record audio anymore because of this. I went to my sound setting and did not know what to do.
In my sound settings under "playback" I have
AMD HDMI Output
AMD High Definition Audio Device
Not Plugged In
OutPut
Avid Mbox
ready
Speakers and Headphones
as "Default Device"
Communications and Headphones
as "Default Communication device"
Under " recording " I have
Input
Avid Mbox
Ready
External Mic
IDT High Definition Audio CODEC
ready
Internal Mic
as "Default device & Communication device"
Stereo Mix
Currenty Unavailable
Do I have my communication devices and Default devices on the wrong thing?
http://youtu.be/gHhcJp33kIM
I tried this video but I don't think i did it correctly.
If you can't help me do you think I should called Avid or Fl studio?
Whenever i go to Avid Mbox ASIO (underneath ASIO4ALL v2) ,the part where it's says
Show ASIO panel is not there and "Not enough ASIO output channels available.At least 2 channels are needed." pops up
Old 05-26-2013, 04:05 PM
guatamas guatamas is offline
Default Re: Not enough ASIO output channels available.at least 2 channels are needed.
I have seen this happen when FL crashes or PT Crashes and I try to open up FL Studio. One of your programs is using the asio drivers when you launch FL. This also appears when you select the wrong mbox asio device (there are 2, the one you selected and the other has a similar name). If there isn't another mbox asio device in your menu try uninstalling asio and mbox drivers. Also make sure you don't have any programs running in the background
Selective enabling of ASIO channels in Pro Tools Siegfried Meier Windows 2 01-28-2012 09:10 AM
DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available. scottthafoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 04-19-2010 01:45 PM
Error: Channels 0/0 could not be set on ASIO driver chili1222 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-03-2009 09:59 AM
More input channels needed LynxAudio Tips & Tricks 3 08-15-2007 10:47 PM
can i use my hd hardware as an asio 2 channels devide polnetwork.com Pro Tools TDM Systems (Mac) 10 10-15-2002 09:55 AM
