iLok Error? Help
It all started when I have another external sata/usb3 connected: Pro Tools suddenly said "missing ilok"... then everytime I boot my computer, pro tools said missing ilok, but once I move the ilok to another USB port , I can open pro tools.
PC: 3930 Intel, Pro Tools HD Native which part could be wrong? |
Re: iLok Error? Help
Many areas - USB ports themselves could be an issue
I didn't notice what side we are on Mac / PC But try connecting the drive first and then connecting the ilok Experiment
I wonder if my ilok is broken.... As I heard that connecting ntfs may broke licenses in ilok, as sometimes Pro Tools dialogue mentioned this.
Shorten the drives file name.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Drive Name? or File Directory name?
Have you turned OFF the power management feature on all USB ports(called USB Root Hub in Device Manager)? And I would only put the iLok in a USB2 port(not the blue USB3 port) if you can help it.
Previous versions of ProTools had issues with the actual drive name being beyond 13 letters if I'm remembering correctly
So in the case that sunburst replied to you the actual drive name
It used to be that when installing the iLok drivers it would give you the message about the amount of characters in the drives name. If I was over x -amount a lose of authorization could occur. Spaces count towards the total by the way. I'll check iLok for the exact amount of characters. EDIT: Didn't find the info at iLok but googling it turned several references of it being 11 characters total.
I know about this . But why everything is running smoothly and good until one day when my computer is connected to my friend's HD thru usb3/esata then suddenly this ilok problem occured every time?
As mentioned it could be a drive name that's to long, a USB port power management issue. Possibly something related to USB3.0 As far as why the iLok would work again when being moved to a different port to could be that its reinstalling the iLok driver since its being recognized as new hardware on that port. Or its waking the port upon insertion. The simple answer is that it doesn't like your friends external drive.
iLok error - PT 10.3.6 | DAS-Mike | macOS | 7 | 03-27-2014 04:18 PM |
iLok Error? | foolery | Windows | 7 | 01-08-2014 10:37 AM |
Help Please - iLok Error! | Chingy | Pro Tools 10 | 2 | 12-21-2011 06:48 PM |
Help! Ilok run time error while moving license to another ilok. | poem | Pro Tools 9 | 5 | 11-27-2011 06:30 PM |
error: missing ilok authorization for pro tools 9. please insert the necessary ilok.. | weakluv | Windows | 2 | 07-07-2011 05:47 PM |
