Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Mac)
Old 03-29-2013, 12:37 PM
chinopepito chinopepito is offline
Default PT10 elastic audio unable to analyse audio files
Aloha,
I am running 10.3.2 on OS 10.8.2 on a 2,9 PB, 8GB of ram
Doesn't matter what kind of session i open and how big the clips/files are. If i try to use Elastic Audio the clips get greyed out and you don't hear them anymore. The task manager says "analysing audio" but without any progress.
Any solution for this problem?
Thank you very much in advance
Jens
Old 03-30-2013, 02:13 AM
Default Re: PT10 elastic audio unable to analyse audio files
Update
Actually it seems like the plug in has problems opening at all. If i double click the Elastic Audio plug in the little plug in window opens but stays empty.
Any suggestions?
Greetings
Jens
Old 03-30-2013, 06:06 AM
Stig Eliassen's Avatar
Which file format (.wav, .aif, etc)? I believe I've heard/read about issues with audio files other than .wav or .aif, but I'm not sure about this. I'll keep looking for info.
Have you tried trashing PT preferences?
Pro Tools|HDX 12.7.1 | Logic Pro X | Avid HD I/O (8x8x8) | 6-core 3.33 Westmere w/24GB RAM | OS 10.12.3 | D-Command ES | Eleven Rack | Vienna Ensemble Pro 5
Old 03-30-2013, 06:41 AM
Hello Stig
thanks for your reply. I am using wav's only.
Just trashed the digidesign/protools preferences and now at booting PT i get the message that: "Pro Tools could not load the Elastic Audio Plug in because no valid authorization could be found, the iLok was not connected or the plug-in was damaged"
Once the session is open and clicking on the Elastic Audio button it tells me the EA plug in is not installed.
BAD
(of course i am running an authorized version of PT10 with the iLok connected )
Greetings
Jens
Old 03-30-2013, 08:07 AM
Have you checked in the plugins folder?
I would re-run the PT 10.3.2 installer in case something didn't install properly.
Click image for larger version
Name:	Screen Shot 2013-03-30 at 3.26.46 PM.jpg
Old 03-30-2013, 08:22 AM
Dear Stig,
It looks exactly like your image - thanks a lot for doing the effort of posting - I am afraid the plug-in is broken indeed. Not working at home at the moment where the installer is on a safe place on an external HD - so I guess i have to live without EA for the next few days and try to re-instal it as soon i got home.
Thanks so much for your help
(by the way - do you think there is a way to download only the broken plug in somewhere?)
greetings
Jens
Old 03-30-2013, 08:49 AM
No, not the elastic plugin. It's embedded in the PT installer. I would even download the PT installer again, in case something happened the last time.
Old 03-30-2013, 10:02 AM
Thank you Stig
downloading the installer and re-installation of PT was the way to go,
Wish you a happy easter
grtz
Jens
Old 03-30-2013, 11:03 AM
Originally Posted by chinopepito View Post
Thank you Stig
grtz
Jens
Good to hear. Happy Easter to you too.
Elastic Audio hangs PT10 suicune Pro Tools Software (Mac) 21 06-03-2014 12:10 PM
Elastic audio bug in PT10 + 11HD Boe Larsen Pro Tools HDX & HD Native Systems (Mac) 5 01-22-2014 06:54 AM
Elastic audio is unable to perform error Rwilliams0190 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-18-2010 10:41 AM
Elastic audio is unable to perform error Rwilliams0190 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-05-2010 07:06 AM
unable to switch elastic audio off Ale Post - Surround - Video 0 02-14-2008 02:34 AM
