Old 03-19-2013, 05:48 AM
phillyt2k phillyt2k is offline
Default Dramatic pitch rise effect - how to??
Ok, so I'm trying to create a similar effect to this in a track I'm working on. The particular effect in question is between approximately 1:40 and 1:54. Just a (should be) basic pitch bending of a looped vocal.
Now I have my singer and have chopped up his vocal and looped/repeated it a ridiculous amount of times so it lasts "forever" so I have plenty of vocal to play with.
I had this problem last year in Logic trying to create the same effect and ended up creating it in FL studio and exporting the wav into Logic.
There must be an easy way to do this. It was simple in FL Studio.
I need to pitch it up (i think) by like 2400 cents, in Logic using various methods I could only get it to 1200. Is there any way to do this natively in PT or do I need 3rd party software?
Cheers to anyone who can help :)
Old 03-19-2013, 06:25 AM
DJ Bechara's Avatar
DJ Bechara DJ Bechara is offline
Default Re: Dramatic pitch rise effect - how to??
Automate the pitch plugin in pro tools
Bechara Saliba
Old 03-19-2013, 08:04 AM
Thats the way i've tried it but it doesnt sound right, has a strange sort of artefact to it. Plus after the rise I need it to drop down to nothing like practically top, doing it with this makes the vocal just go back to the original pitch.
Does that make sense?
Old 03-19-2013, 08:09 AM
crizdee's Avatar
crizdee crizdee is offline
Try Vari-Fi audiosuite
Chris
Producer, Engineer,
UKmastering E-Mixing & Mastering facility
www.ukmastering.com
PT10.3.7 Lion HD6 accel Magma PE6R4 Control 24 Harpertown 8-core UAD-2 Quad / SSL Duende Native. Manley Vari-Mu, Manley Massive Passive, Solid State Logic VHD, Anthony De Mario ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 03-19-2013, 10:55 AM
soybalm soybalm is offline
Waves graphic soundshifter. Put the link mode on unlink. leave the left line as is and raise up the right line. It defaults to maximum which is an octave so just process twice if you need to. If you need the tempo to speed up then link tempo and pitch.
This is all done in the audiosuite. make sure you lower the render head and tail time from 2.0 to something like 0.1 instead or load the wave form in the plug in and plot your points by double clicking on the line.
I want to add that you can make your looped note a consolidated file;select then press, shift alt 3 on a pc. This will be the way to process it and you can export that consolidated file in to an audio editor program which should have no problem handling this.
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
Old 03-19-2013, 11:25 AM
joachim's Avatar
joachim joachim is offline
Maybe this will work (tested with a small speech sample) :
instrument track with structure free sampler
midi track routed to instrument track
the chopped vocal part to be repeated and to be pitched-up -> put in the structure free as a sample
midi track with notes for each repetition
midi track pitch bend in track view, draw line upwards to the end of the repetitions as desired
And I believe, that Vari-fy does only work from original pitch to zero or from zero to original pitch (not original to 400%).
PT 11.3.1 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 64GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 03-20-2013, 05:45 AM
DJ Bechara's Avatar
joachim method is very similar to the one you use in FL Studio I guess since Structure is a sampler in which you load the wav file and tweak the midi note which is basically playing the sample ... just like FL ...
Bechara Saliba
Old 04-28-2013, 07:28 AM
So I'd have to buy an additional piece of kit to do it?
Just tried that, it doesnt give me the amount of range I want tho, it's still not high enough, even at the top (8191). Your right about vari-fi also
Old 04-28-2013, 07:41 AM
joachim's Avatar
Maybe : all those repetitions could be audiosuited with Pitch Shift individually.
If more than 2 octaves are necessary, Pitch Shift may be applied again to a clip that has been already shifted by 2 octaves.
Old 04-28-2013, 11:35 AM
yeh i thought about doing it that way, just seems a long way to go around it. Might as well just do it in FL then bounce it out as a wav.
you seem to be very knowledgable in pitch shifting, can you shed any light on this
Pitch rise effect and loop recording at a later date phillyt2k Pro Tools 10 0 04-14-2013 08:50 AM
Does pro tools have a pitch bend effect? davetheone Tips & Tricks 14 01-29-2009 06:15 AM
How to do "slow pitch down" effect in PT? emde 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 02-14-2006 01:34 PM
pitch effect dat Pro Tools TDM Systems (Mac) 1 12-31-2004 03:35 AM
Delay/Pitch/Octave effect milesyoung Tips & Tricks 0 06-20-2003 09:10 PM
