Old 02-07-2013, 08:06 AM
elmodagansta elmodagansta is offline
Default Mbox Micro with PT 8 LE + Focusrite Scarlet 2i2
Hello, I would like to ask if following configuration is possible:
I would like to edit in PT 8 LE which is obtainable buying used Mbox Micro but for input I would like/must use other interface (Scarlet 2i2).
Is it possible to route inputs and outputs in such a way that the Focusrite becomes the 'deafult' input/output device?
Or I would be able to record through Focusrite (in other software) and then have to transfer tracks to PT sessions and playback through Mbox Micro?
Hope my writing is easier to understand than my thoughts. I would appreciate your help on this. Thanks in advance.
Digirack 003 + ProTools12
Mac mini 2014; SSD 128; i5 2.6; 8GB; OS 10.13
Last edited by elmodagansta; 02-07-2013 at 08:08 AM. Reason: posted in wrong thread, sorry!
Old 02-07-2013, 10:43 AM
nst7 nst7 is offline
Default Re: Mbox Micro with PT 8 LE + Focusrite Scarlet 2i2
PT8 must have a Digi/Avid interface, so you can not use the Scarlett. You can use it with PT10.
Old 02-08-2013, 02:57 AM
Thanks very much for this answer. Although it is not optimistic it ends the subject :)
scarlet 8i6 davidlustrup Windows 2 12-22-2011 12:56 AM
transfuser with protools 9 and focusrite scarlet 8i/6 zela8 Virtual Instruments 0 10-16-2011 10:27 PM
:confused: Pro Tools HD playback thru Mbox/Mbox Micro? JazzBum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-06-2010 07:27 PM
Mbox 2 Micro with audio out from Focusrite Liquid Saffire 56 JosephJones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-04-2010 05:38 AM
mbox micro + mbox 1 + software compatibility question driches 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-15-2008 08:29 PM
