Old 01-10-2013, 08:40 AM
bcwiz's Avatar
bcwiz bcwiz is offline
Default Windows drivers for digi 002/003
So we have new drivers for Mountain Lion for Digi 002/003.
DigiTechSupport when can we expect a driver update for Windows? There are some real problems with the current drivers.
thank you
Brian Campbell
"Air mixes better than any console" Bill Porter
"Humility is mighty important in this business of listening" Bob Olhsson
Old 01-10-2013, 04:20 PM
sw rec sw rec is offline
Default Re: Windows drivers for digi 002/003
Huh.
Mine works just fine.....what problems?
Old 01-10-2013, 06:39 PM
bcwiz's Avatar
Originally Posted by sw rec View Post
Huh.
Punch in/out has a distorted very unprofessional 'glitch' in the audio, like it skips.This is glitching on the playback tracks not the record tracks. The rig records fine this is a monitoring issue.
When the transport is stopped there will very often be a gap then the reverb tail will play.
Often when the transport stops/starts on a transient there will be a short burst of distortion.
See this thread http://duc.avid.com/showthread.php?t=310286 and others going back to PT8.
I went from PT7 to PT10 and that's when this started, same gear.
I have seen it on five completely different 003 rigs.
Brian Campbell
Old 01-11-2013, 10:48 AM
bcwiz's Avatar
Installed an old Echo Mia card using ASIO4all and the rig punches in/out with no problems. Please fix the Digi 002/003 drivers!!!
Brian Campbell
Old 01-11-2013, 11:17 AM
Since this is a USERS forum, you might have better luck submitting a request right to Avid CSA. Incidentally, running an 002 on PT 10 (just upgraded from 8.x) with NONE of these issues. A sandra report on your machine might be in order to see if there's a related issue.
Old 01-11-2013, 04:15 PM
bcwiz's Avatar
Here's the Sandra from one of my rigs. I can quick punch 32 tracks at once all day long with an EQ and compressor plug on every track with a convol reverb on an aux at a buffer of 64. The rig runs fine, it's this stupid monitoring issue.
SiSoftware Sandra
ID
Host Name : Digi003R
Computer
Model : OEM System Product Name
Serial Number : System Ser**********
Chassis : Desktop
Mainboard : ASUS P5B-E
Serial Number : MB-123*******
BIOS : AMI (OEM) 1601 07/13/2007
Total Memory : 7GB DIMM DDR2
Processors
Processor : Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz (2C 2.13GHz, 2MB L2)
Socket/Slot : FC LGA775
Chipset
Memory Controller : ASUS P5B 4x 267MHz (1GHz), 2x 4GB DIMM DDR2 802MHz 128-bit
Memory Module(s)
Memory Module : Kingston 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3)
Video System
Monitor/Panel : Samsung SyncMaster
(1600x1200, 19.1")
(1600x1200, 19.1")
Video Adapter : NVIDIA GeForce 8600 GT (4CU 32SP SM4.0 1.19GHz, 512MB DDR3 1.4GHz 128-bit, PCIe 1.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA GeForce 8600 GT (32SP 4C 1.19GHz, 512MB DDR3 1.4GHz 128-bit)
Compute Shader Processor : NVIDIA GeForce 8600 GT (32SP 1.19GHz, 512MB DDR3 1.4GHz 128-bit)
CUDA GP Processor : NVIDIA GeForce 8600 GT (32SP 4C 1.19GHz, 512MB DDR3 1.4GHz 128-bit)
Storage Devices
Seagate ST3250310AS (250GB, SATA300, 3.5", 8MB Cache) : 233GB (C:)
Seagate ST3320613AS (320.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 298GB (D:)
HL-DT-STDVD-RAM GH22NP21 (ATA66, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
Logical Storage Devices
System (C:) : 233GB (NTFS) @ Seagate ST3250310AS (250GB, SATA300, 3.5", 8MB Cache)
Audio (D:) : 298GB (NTFS) @ Seagate ST3320613AS (320.1GB, SATA300, 3.5", 7200rpm, 16MB Cache)
Optical Drive (E:) : N/A @ HL-DT-STDVD-RAM GH22NP21 (ATA66, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : ASUS P5B
LPC Legacy Controller 1 : Winbond W83627DHG
Disk Controller : ASUS 82801H (ICH8) 4 port SATA Controller
Disk Controller : ASUS 82801H (ICH8) 2 port SATA Controller
Disk Controller : ASUS P5B [JMB363]
USB Controller 1 : ASUS P5B
USB Controller 2 : ASUS P5B
USB Controller 3 : ASUS P5B
USB Controller 4 : ASUS P5B
USB Controller 5 : ASUS P5B
USB Controller 6 : ASUS P5B
USB Controller 7 : ASUS P5B
FireWire/1394 Controller 1 : Avlab Technology XIO2200(A) IEEE-1394a-2000 Controller (PHY/Link)
SMBus/i2c Controller 1 : Intel ICH SMBus
Network Services
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.3
Brian Campbell
Old 01-11-2013, 04:28 PM
bcwiz's Avatar
I would be interested in what rig you are running. Also I am running PT10HD.
Brian Campbell
Old 01-11-2013, 04:38 PM
nigelpry's Avatar
nigelpry nigelpry is offline
Angry Re: Windows drivers for digi 002/003
Just so you know over here in Windows land ...
The so called 'updated' drivers for the 002/3 for Mac Mountain Lion are not updated drivers at all. They are still the V9.0 versions. All that has been released is an updated installer, as the older one would install drivers in Lion but not Mountain Lion. You could install in Lion and then upgrade the OS to Mountain Lion. The new release just avoids that step.
After installing, the individual audio and midi drivers are still the V9 versions.
And MIDI is still completely non-fuctional in Mountain Lion. Even worse, the installer still installs the non-fuctioning midi drivers, which then conflict with any functioning drivers you might have for other midi gear, so they have to be removed manually in order to get any other midi drivers working again.
I'm guessing that'll be the last 'update' for the 002/3, there's been no hint of any forthcoming fixes for the problems us 002/3 users are having on the mac side of things.
Old 01-11-2013, 04:50 PM
bcwiz's Avatar
So I borrowed an Mbox2 and guess what... works fine, no noise when I punch in/out, reverb tails are playing properly even at lowest buffer settings. I'm telling you the Digi 002/003 drivers need to be fixed!
Brian Campbell
Old 01-11-2013, 06:49 PM
bcwiz's Avatar
That stinks. So what we need is Digi002/003 drivers version 10 for Mac and Windows please. ASAP
Brian Campbell
Is standalone Windows Audio Drivers v8.0.3 compatible with WINDOWS XP 64 ? VonHelvete 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-28-2010 10:01 AM
digi 002 windows vista drivers? babymanuel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-18-2007 07:52 AM
windows XP Pro/Digi 001/Drivers.. Where??? saavadra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-19-2003 02:50 PM
Ok Digi, I now need Windows Mbox drivers Nitronick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-19-2002 11:46 AM
Windows 98 drivers MikeA Digidesign Hardware & Software 1 06-01-2000 01:51 PM
