Old 12-22-2012, 11:10 AM
fonzi fonzi is offline
Default MBox Pro and FireWire/Thunderbolt adapter
I recently purchased an iMac and am interested in setting up my MBox Pro to work with it. I had forgotten that the MBox Pro only supports FireWire (not USB) and my iMac only has USB and Thunderbolt connections. I noticed that Apple does sell a Thunderbolt to FireWire adapter (http://store.apple.com/us/product/MD...rewire-adapter), however some of the customer reviews are complaining that the adapter slows down the connection speed.
My question: has anyone successfully used this adapter with their MBox Pro? Has it worked out? Do you have any other recommendations for the best/most performant way to connect the MBox Pro to an iMac?
Thanks!
Old 02-03-2013, 09:22 AM
Northwood Northwood is offline
Default Re: MBox Pro and FireWire/Thunderbolt adapter
I bought a Late 2012 iMac and MBox 3 Pro assuming the Apple Thunderbolt to Firewire adapter would connect the two. The MBox came with what I will describe as an 'old style' not-mini Firewire cable and an Adapter labeled 'IEEE1394', which converted the male Firewire connector to a 'new-style' not-mini male Firewire connector, which fits into the Apple Thunderbolt to Firewire Adapter.
The MBox application, nor Pro Tools on OSX does not recognize the hardware as connected.
I have double checked the connections and tried both Firewire ports on the back of the MBox 3 Pro and tried both of the Thunderbolt ports on the back of the iMac.
I have tried booting with the wires connected and MBox on and with MBox off and turned on after boot and with wire disconnected until after boot.
Has anyone gotten this configuration to work?
If not, are there any suggestions other than replacing my iMac with one containing a native Firewire port or replacing the MBox 3 Pro with a audio interface that supports Thunderbolt or USB 3?
Old 02-03-2013, 11:20 AM
emilano emilano is offline
It works great for me!
Old 02-03-2013, 11:50 AM
Bruce Paine Bruce Paine is offline
Admin Emeritus
Works for me as well with a mid-2011 iMac and Mbox 3 Pro. Did you install the latest Mbox Pro drivers?
www.avid.com/drivers
Bruce Paine
System Details
Old 02-24-2013, 10:07 PM
djlessthan djlessthan is offline
I'm also curious about this...anyone else have any luck?
Old 02-25-2013, 03:32 PM
herman_hdz herman_hdz is offline
Sorry guys, I have a similar issue , and some people recommends me to buy this adapter, so based on your experience think that my OSX Mountain Lion can recognize my MBOX Pro3 connected through the adapter Thunderbolt to FireWire instead of my integrated FW port in my Imac 2009 with 10.8.2 and using the last drivers available for Mountain Lion Release: 1.1.3 (Oct 30, 2012)??
Thank you.
Old 03-26-2013, 08:11 AM
Bruce,
are you using a Thunderbolt adapter to connect to the MBox 3 Pro?
I have the latest drivers from http://avid.force.com/pkb/articles/e...ownload+driver
Driver 1.1.4 Oct 30, 2012
There is an MBox process (that contains an image of an MBox 3). The Update button takes me to the above driver page.
Old 08-24-2013, 11:46 AM
tr0n tr0n is offline
realize this thread is fairly old...however anyone using any of the new iMacs, MacBook Pro (Retinas), etc with FireWire only devices from AVID.
The FireWire to Thunderbolt adapter works great..my one additional suggestion is to get a FireWire 400-to-FireWire800 Cable and not use the adapter, multiple adapters have spelled out bad in the past.
Old 08-25-2013, 10:32 AM
Sorry I didn't update on this issue:
I bought a FireWire 400-to-FireWire800 Cable to use with the Apple Thunderbolt Adapter and reinstalled the MBox Pro 3 drivers and the MBox Pro app could recognize the hardware.
In PT > Setup > Playback Engine, I could set to MBox and get the analog and MIDI INs and OUTs available in PT.
Thanks all.
Old 09-06-2013, 03:09 PM
pitchie pitchie is offline
Ever since buying my new iMac, it frequently (often daily) crashes when it comes out of sleep with the MBox 2 Pro connected, using the Thunderbolt to FW adaptor (obviously, since it's the only way to connect the two devices). When I'm up and running, things are fine! I have tried everything, including updating drivers and the Mac OS to 10.8.4... I'm using Pro Tools 9 but that doesn't really matter, as I don't have to be using Pro Tools to experience this crash. I'm going out of my mind here, having searched for an answer all this year!!
AC adapter for Mbox Pro 3 Firewire Billiam1959 FireWire and USB Audio Interfaces (Mac) 0 08-28-2013 12:28 PM
Thunderbolt drive with MBox Pro (firewire 400) KingTor macOS 2 11-13-2012 05:18 AM
Apple $29 Thunderbolt to Firewire adapter now available nst7 Pro Tools 10 1 08-01-2012 07:38 AM
Mbox 2 Pro - Firewire or power adapter? ffernandes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-06-2010 08:29 AM
MBox Pro 2 - run w/ firewire only or with adapter Freis968 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-14-2007 08:23 PM
