Avid Pro Audio CommunityHow to Join & Post • Community Terms of Use • Help Us Help YouKnowledge Base Search • Community Search • Additional Resources |
Is an Mbox 1 compatible with Protools 8 LE running Windows Vista 32Bit?
With the Mbox connected per USB it says : Unable to locate Mbox Hardware Make sure Hardware is connected and turned on I've tryed about everything I know, but does admit I'm as lost as a ball in high weeds on this stuff,, and I've read here on the site till i'm blue in the face,, begging to look like papa Smurf!! ![]() any ideas? thank you, cubs |
Original Mbox should work with LE up to version 8.0.1(so 8 without any updates should be fine). Maybe you have hardware issues? The only way to know is for you to post a Sandra report as described in this thread, found in the top section of this and every DUC page:
Help us Help You - READ THIS Before Posting! Then there are the required system tweaks(which actually NEED to be done).
Asus x99, Intel i7 6800K, 32 gig DDR4, GeForce 750 Ti, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs and Midas.............................. https://www.facebook.com/search/top/...0sound%20works www.capricornsoundworks.com The better I drink...the more I mix..... ![]() BTW, my name is Dave, but most people call me.........................Dave |
Ok, I have no clue what a "Sandra" is,, but I'm going to start over with explanation of what is going on here,, I've made some changes so here goes:
Toshiba Satellite Laptop Windows 7 Ultimate Service Pack 1 Processor Intel (R) Pentium (R) Dual T3400 @ 2.16Ghz Ram 4gb System Type 32 Bit When you boot the system if I have the Fast Track or the MBox connected it shows that the correct Driver was found for the Device. You can go to device manager and check and it shows the driver to be operating correctly. But when Starting Protools I get the message: Unable to locate M Audio Hardware,, I have not a clue what to do,, Thank you for any assistance ![]() cubs ![]() |
Pro Tools LE does not work with M-Audio hardware. You need Digidesign/Avid hardware for LE, or Pro Tools M-Powered for M-Audio hardware.
The Interface I'm trying to use is a Digidesign/Avid Mbox
Also trying to get an M-Audio Fast Track to work and neither will pull the software up. Protools M Powered Essential 8.02 I did the computer optimization, like the video teaches,, The computer shows the drivers for both devices to load properly,, One of these interfaces should work,, it seems to me like,, about ready to throw it all in the garbage,, buy a hard drive recorder,, lot less trouble,, I just read where the Original Mbox is supposed to work with Up to 8.0.2 and that's what I have,, but can't get either interface to work. cubs ![]() |
As I said, the Mbox is not going to work at all. M-Powered software is only for M-Audio hardware, so start by updating or reinstalling the driver for the Fast Track.
Thank you Albee,, the Fast Track Driver got it to running with Windows 7,, So is it safe to say that the Mbox is useless as tit's on a boar hog huh?,,
![]() ![]() cubs ![]() |
![]() Quote:
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
What version of 8 will it actually work with and does the windows have to be XP to support it?,, Thank you for buzzing in,,
![]() Merry Christmas! cubs ![]() |
![]() Quote:
Info here halfway down the page. 8.0.1
7.4 compatible with mbox 1? | req06 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-27-2008 12:32 PM |
10.4.6 compatible with an Mbox | Jace Everett | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-07-2006 04:38 PM |
UAD-1 not compatible with Mbox !? | Archmart | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-10-2005 03:28 AM |
DP3 and Mbox? are they compatible? | brasa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-13-2004 11:33 AM |
Is the Mbox compatible with the G5? | Imagine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-08-2003 03:42 PM |
