Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 12-12-2012, 08:08 AM
everettb21 everettb21 is offline
Default Exporting a session problem
i did a session copy to desktop to dvd to take over a friends house to add mores parts.
my friend has protools express on windows 8 and i have mac pro osx lion
7.5.
of course i compress the files before they went to dvd.
on the pc i extracted all the files,opened session mix window came up. hit play button no sound. Checked for audio files,no audio files.
Can protools express on win8 read a session from mac osx lion 7.5 using protools 10. Is it something different i need to do ?
everything from the was there except the audio files.
thanks
Old 12-20-2012, 04:06 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Exporting a session problem
7.5.
thanks
Just to confirm.
The way to do this is to use the option in the save menu "save copy in" then save the session to a new location on your hard drive.
Also remember to click the box for Items to copy "audio files" otherwise you will not be including the audio!!
Note: another good thing to do before doing this is to use.. select>unused, in the clip menu then select clear in the clip menu and just remove unusued files from the session. This will stop you from including all the unused clips that are not active in the session but will still take up disk space, especially if you want to zip the session and send it internete etc.
P.S. I dont use Express, so cant confirm all these functions are part of express!!!!!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-19-2018, 01:06 AM
Vee Vee is offline
I'm having serious issues with a Pro-tools file. First I have tried endlessly to export the project and it starts but eventually stop somewhere. Since that didn't work, I decided to do my vocals inside the project and export later. However, it has refused to export and after encountering a 9013 error message, a major part of the recorded vocals goes missing. Please what to I do to recover vocals and eventually export the file
Consolidating / exporting a session peter5992 Post - Surround - Video 3 04-20-2013 08:55 AM
Exporting Session Help?? mprev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-09-2009 04:08 PM
Exporting Markers to New Session Gilliss Tips & Tricks 5 01-26-2007 08:40 PM
Exporting PT session to Logic 7.1 malgfunk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-18-2005 09:13 PM
If I edit files after exporting to 2nd session, how is 1st session affected? el biciclista 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-02-2002 12:01 AM
