Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Mac)
Old 12-11-2012, 03:40 PM
samuel497 samuel497 is offline
Default pro tools 9 compatibility with my mac
Hi
Can anyone confirm if pro tools 9 will work on my white macbook not pro mid 2007 model.
Running snow leopard 10.6.8 and has firewire port
I have found a website that mentions that all white macbook that have firewire port are supported but on avid official site it does not list it as a qualified computer.
I have bought an apogee duet and would prefer to use pro tools as i am more familiar with it than logic pro.
And just out of interest is there any chance at all of pro tools 10 working
thanks in advance
Sammy
Old 12-11-2012, 03:59 PM
Chief Technician's Avatar
Post Re: pro tools 9 compatibility with my mac
Originally Posted by samuel497 View Post
Hi
Maybe.
Good to know, though in this case the only useful information is the firewire port.
The AVID website uses a different way of identifying the models. It uses the codenames of the processors that were used.
http://avid.force.com/pkb/articles/e...547?popup=true
Here is how you reconcile the information in that document with what model MacBook you have. Go to the Apple menu and hold down the option key while selecting About This Mac. It will change to System Profiler... In System Profiler, select Hardware in the left column, and in the right pane look for a line that reads Model Identifier. If your MacBook is listed as MacBook2,1 (or earlier) it is not supported.
That's fine.
Yes, but only if it is not a MacBook2,1 (or earlier).
Old 12-11-2012, 04:13 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Default Re: pro tools 9 compatibility with my mac
I used to run PT 9 on a white 2006 macbook, with 10.6.8, so you should be fine.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 12-11-2012, 05:05 PM
I checked and it says macbook 2,1
Old 12-11-2012, 06:29 PM
Should be the same model I used to have. While it's apparently not officially supported, it worked for me with PT9.0.3 and OSx 10.6.8.
- John
Old 12-11-2012, 09:35 PM
nst7 nst7 is offline
If it helps at all, I had a 2007 Imac for five years. I ran Tiger, Leopard, and Snow Leopard, and in that time I also ran Protools 7, 8, 9, and 10 on it. All very successfully.
Old 12-13-2012, 02:37 PM
KingTor KingTor is offline
We had a mid 2006 Mac Book Pro which seemed as though it would be 100% compatible with PT 9 on paper, but it did not work at all when we were trying to work to picture, etc. It may very well have worked fine for other workflows, but I didn't test anything aside form what we needed.) If there's any way you can install a demo before spending money, I would highly recommend it. And stay in 10.6.8 if you can, 9.0.6, the version that works in 10.7, is still beta for a reason.
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
pro tools 10 compatibility djecaron16 Pro Tools 10 2 09-06-2013 05:34 PM
Pro Tools 9 and M box compatibility tombh Pro Tools 9 2 11-18-2010 06:40 AM
Pro Tools 8 and Mac G4 compatibility swgerow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-23-2009 11:53 AM
Compatibility from pro tools 7 to 6 ped Pro Tools TDM Systems (Mac) 2 03-28-2006 01:56 PM
M-Box to Pro Tools TDM / HD compatibility ? SportsSounds Post - Surround - Video 1 12-17-2003 09:15 AM
