Hello All,
Using ProTools 10.3.2 on Win7 x64. I'm testing all different options for "Pan Depth" under the Session Setup menu. I'm doing this: 1) I have a mono track 2) I have a Quad bus, with 2 stereo subpaths 3) I'm routing the mono track to one of those stereo subpaths Not working, the Pan Depth is fixed to -3 dB. I know the documentation says so and that Pan Depth is configurable only for stereo routings, but I really think this is the case where it should work, since the mono track is being routed to a stereo path, even if that stereo path is a subpath for a quad path. Also, there's definitely a bug here, whether you think this should be the case of a working Pan Depth or not. If I: 1) Change the routing of the mono channel to a pure main stereo bus, routed to the main stero monitors, then Pan Depth works (yes, it's supposed to). 2) After testing different Pan Depth settings and seeing it works, I change the output the mono track to the original stereo subpath, then it continues to work! ![]() So, either there's a problem preventing it from working at first, or a problem allowing it to work at the end. Please let me know what do you think. ![]() Cheers, Francisco
The audio world is full of (mainly very expensive) placebos. ![]() Latest (subscription) Pro Tools Ultimate on Windows 10 Pro x64 Mbox 3 Pro + Eleven Rack (ERXP) Asus Prime 299X Deluxe Intel Core i9-7940X 4.3 Ghz (14 cores / 28 threads) Ram 8 x 16GB each (128 GB total) Kingston HyperX Fury DDR4 3400 MHz Dual Samsung 970 Pro M.2 1TB (OS and WIP) 2 x Seagate Barracuda Pro 10TB mirrored for archive and backup Asus/Nvidia GTX 1080 TI with a single 4K monitor Dell P2715Q |
I've had to solve this by creating 2 main stereo busses and later pointing them to the stero sub-busses in the quad bus.
Still, there's a bug here.
Mixture of Mono and Stereo busses | jeremy@jjlee.com | VENUE Live Sound Systems | 5 | 12-06-2012 12:59 PM |
What is variable stereo pan depth? | KevinAllen | Pro Tools 9 | 6 | 11-07-2010 12:22 PM |
How to Downmix 5.1 to Stereo via aux/busses | vudoo | Post - Surround - Video | 5 | 03-25-2009 08:43 PM |
mono or stereo aux busses for effects | peter99 | Pro Tools TDM Systems (Mac) | 7 | 06-20-2006 06:43 PM |
Setting monitor bit depth of AV Option | Samhein | Post - Surround - Video | 3 | 04-22-2001 08:21 PM |
