Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Win)
Old 10-27-2012, 10:51 PM
oNeKOG oNeKOG is offline
Default iLok Driver Installer wont install
Just got windows 8 Pro and everything is going fine till I try to install iLok Driver Installer (DriverSetup.exe)
The file opens then just sits there with the bar filling up over and over again.
it's installing required Microsoft dlls and never finishes.
On the Ilok site windows 8 is supported.
What can I do?
Thanks in advance.
Ibanez RG7
Marshall Valvestate VS30R
Pro Tools 11
Boss GT-100
Intel Core i7 2600K @ 3400MHz
Asus P8Z68-V PRO GEN3
16384 MB Ram
GeForce GTX 660 Ti
Win 8.1 Pro 64X
Thing of it is see, Ya know what I'm saying?
Old 10-28-2012, 12:56 AM
Default Re: iLok Driver Installer wont install
Ok uninstalled everything that has to do with pro tools reinstalled only pro tools and now getting "Could not allocate memory for the disk cache. Tyr lowering your disk buffer (DAE Buffer) disk cache size or engine voice count. If you got this error on launch, delete your prefs and try again. (-9514)"
Did that now I get "DAE Error -13001 was encountered"
Crazy!!!!!!
Found the fix is to run pro tools as admin that gives me the delete your prefs error or the -13001.
Ahhhhhhhhhhhhhhh this sucks.
Ibanez RG7
Pro Tools 11
Boss GT-100
16384 MB Ram
GeForce GTX 660 Ti
Win 8.1 Pro 64X
Old 10-28-2012, 05:50 AM
Peter Kroner Peter Kroner is offline
for transmitting your string to your iLok you´ll need always an old system ...
I made this experience two weeks ago.
Pace iLok is just running for installing strings on 32-bit systems.
When your string is at your iLok you can use other OS´s
Old 10-28-2012, 10:19 AM
The Weed's Avatar
The Weed The Weed is online now
Avid has not qualified and, at the moment, does not support Windows 8 as an OS for Pro Tools.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 10-28-2012, 10:27 AM
If that's the case you think installing a Virtual Machine(VMware I believe) program and run say win xp in it then get PT 10 up and running exit xp vm. Reboot win 8 and maybe just maybe PT will work in win 8? Ooooo I'm exited :)
Ibanez RG7
Pro Tools 11
Boss GT-100
16384 MB Ram
GeForce GTX 660 Ti
Win 8.1 Pro 64X
Old 10-28-2012, 02:04 PM
VM is slow.
If this wont work ill have to install win 7 on diff drive and use it for PT only till win 8 update happens.
what a shame.
Thanks for the help and if anyone has another suggestion please post it ill give it a try
Ibanez RG7
Pro Tools 11
Boss GT-100
16384 MB Ram
GeForce GTX 660 Ti
Win 8.1 Pro 64X
Old 10-28-2012, 04:22 PM
TOM@METRO's Avatar
TOM@METRO TOM@METRO is online now
Originally Posted by oNeKOG View Post
VM is slow.
Pro Tools runs best without other apps installed on the same OS anyway. So this is probably a good idea.
~ tom thomas
Formerly hobotom
Pro Tools HDX~HDN 2018.4
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 10-31-2012, 09:39 AM
Magnerion Magnerion is offline
Default Solution
Just went through the same thing, after some hours on the internet i found a solution.
First uninstall all ilok software that you have on your computer. And take ilok out of your usb.
Install this first Tpkdx64Setup
Reboot
Install this LicenseSupportSetup64
Insert ilok and enjoy!
Files you need: http://www.mediafire.com/?40utiie2c3dqjt6
Hope i've helped you:)
Old 11-04-2012, 02:49 PM
Found the fix.
In....
Pro_Tools_10_3_2_Installer_77970\Pro Tools\Pro Tools Installer
run setup with win 7 compatibility and as admin
That's it works and i'm up and rock and rolling.
Ibanez RG7
Pro Tools 11
Boss GT-100
16384 MB Ram
GeForce GTX 660 Ti
Win 8.1 Pro 64X
Old 02-09-2013, 04:17 PM
rlcowastudio rlcowastudio is offline
this is the fix for getting windows 8 pro and pro tools 10.3.3 working!!! Thanks so much!!!!
Rawb C in Va Beach
There are only 10 kinds of people in the world. Those who understand binary, and those who don't.
ILok driver won't install poppy Pro Tools Software (Win) 7 06-22-2012 10:18 PM
Machine Control BIG installer bug, wont start rbhun Pro Tools Software (Win) 10 02-11-2011 07:26 PM
6.7 Install Fails On PT Driver Installer Third Eye Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-01-2006 11:28 PM
Mbox driver wont install - freezes computer dharpo32 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-20-2005 09:12 AM
Trying to upgrade to 6.4 but installer wont work! yogitengu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-01-2004 02:05 AM
