Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Mac)
Old 10-23-2012, 12:11 AM
Hovak Hovak is offline
Default Pro Tools 10.3.0 latency issue !!! HELP
Hey AVID.
I was using the previous version of Pro Tools 10 without any problems.
As soon as I updated to this current version, I started having a latency during tracking, even if I lower the buffer size to 32.
Here is what I use.
Mac Pro 2 x 2.4Ghz Quad-Core Intel Xeon
RAM: 32Gb
Mac OSX: 10.7.4 Lion
Audio Interface: UAD Apollo Quad
I did not change any configuration. I just updated to the newest version and that's it.
Please help me to solve this problem ASAP.
Thanks,
Old 10-23-2012, 01:06 AM
priorytools priorytools is offline
Default
Try disabling all plugs in the session first. Then monitor input & see what the latency is like.
Also, it might be worth trashing the DAE & prefs digi set up prefs too.
~ Trashcan Mac Pro late 2013 - 64 GB RAM - 10.11.6 / Pro Tools HD 12.6.1 / HDX 2 + UAD2 PCIe OCTO in Magma Expressbox 3T / HD I/O's x 4 + 1 x 96io / Avid S6 M10-24-5 V3.6 ~
~ MBP 15" 2.8 Intel Core i7 -10.12.5 /Apollo 16 / Steinberg U22 / Artist MIx / Pro Tools HD 12.6.1 - UAD2 V8 / UAD2 Satellite DUO ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / HEAT / Magma PE6R4 / ProControl 24 faders / UAD2 QUAD PCIe ~ ARCHIVE RIG
Old 10-23-2012, 01:22 AM
Default Re: Pro Tools 10.3.0 latency issue !!! HELP
I forgot to mention that I am not using any plugins. I go strait in to Input.
I have tried tracking guitar and microphone. Same issue
Old 10-23-2012, 06:14 AM
WernerF WernerF is offline
Is the latency still there if you toggle Delay Comp off and then back on or if you reboot the entire session?
Old 10-23-2012, 08:34 PM
yes
Old 10-23-2012, 08:51 PM
What are you doing in the Apollo Quad? Any Apollo console plugins running there? Which ones? Try removing all the plugins running in the Apollo console.
What sample rate?
Try turning off input delay compensation (in the Apollo console). Note that your symptoms are exactly what this would cases since IDC adds a delay whether any Apollo/console plugins/upsamplign plugins are in use or not.
You are absolutely certain that the latency is still there if you disable ADC in Pro Tools? (and thar be dragons lurking with ADC and Apollo). We need to be very careful with terminology here because there is both automatic delay compensation/ADC in Pro Tools and input delay compensation in the Apollo.
Darryl
Old 10-23-2012, 09:49 PM
What sample rate?
Darryl
I turned off the Input Delay Compensation on Apollo Console and the problem got solved.
Thank you Darry and the others for your help. I really appreciate it.
Pro Tools 11 Digi 003 Low Latency Monitoring Issue dizzydiscs Pro Tools 11 11 12-29-2013 02:16 PM
Pro Tools 11 latency issue edavidmartinez Pro Tools 11 0 07-21-2013 09:11 PM
Hardware Insert Latency issue in Pro Tools 10!!! HELP !!! Hovak Pro Tools Software (Mac) 14 10-28-2012 10:42 AM
Front end Latency issue w/ Pro tools on a PC cpaul 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-29-2007 07:36 PM
Latency Issue with Pro Tools 7.1cs8 Update!!! xx1messxx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-02-2006 06:03 PM
