Old 10-14-2012, 05:36 AM
malmalibu malmalibu is offline
Cool Pro Tools 10 asio4all HP Pavilion no sound
I have put Pro Tools 10 onto a HP Pavilion dv7 with beats audio and installed asio4all v2 I get "no sound" from the laptop's on board speakers or head phone jack even though pro tools is playing the project ok. The project was recorded and mixed on a Toshiba P300 with pro tools 9. Both laptop's have a m-audio fast track ultra 8R installed on them and they both record and play back fine when the m-audio i/o is used. I did finally get the audio to play on the Toshiba's onboard speakers and Head phone jack and could do the mixdown fine using just the Toshiba when i select the asioall i/o. I did have the "no audio problem" initially with the Toshiba untill i change some of the settings in the asio4all control panel. I have not had the same luck on the HP laptop. Both laptops run windows 7 the Toshiba is 32bit and HP is 64bit Both have 2 hard drives. Is there any chance that there is a solution to "no sound" on a HP Laptop on board sound system??? Any advice would be appreciated Cheers
Norman A Hamley www.malibugroove.com & www.timelessrocknroll.com
Old 08-29-2013, 06:22 PM
Default Re: Pro Tools 10 asio4all HP Pavilion no sound
Have found a fix that has worked for this issue
See thred http://duc.avid.com/showthread.php?t=343763
Cheers
No Sound Pro Tools HP Laptop asio4all malmalibu Pro Tools Software (Win) 14 11-25-2013 04:47 PM
No sound from Beats audio system on board HP Pavilion DV7 Laptop malmalibu Pro Tools Software (Win) 1 08-29-2013 06:20 PM
No Sound from ASIO4ALL v2. Need help or another option. BelmontBrews Pro Tools Software (Win) 4 10-05-2012 07:13 PM
For Standalone using ASIO4ALL, No sound from other applications spland Pro Tools 9 1 02-22-2011 10:36 AM
ASIO4ALL and Pro Tools? Diesel1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-12-2005 08:01 AM
