Loss of Plug-In authorization keys may occur
When I launch my PT10, I got the
WARNING: Loss of Plug-In authorization keys may occur. This system contains one or more drive(s) formatted with NTFS, which have volume names longer than 11 charaters. This combination is known to corrupt some InterLok Plug-In authorizations. If you know which drives are authorized and they are not configured this way, or if you have no InterLok protected plug-ins, then you may continue. In order to remedy this issue before corruption can occur click "Yes" to quit Pro Tools and rename NTFS volumes to names that are 11 characters or less. Next, re-launch Pro Pro Tools and this dialog should not appear. What is NTFS? How should I remedy this issue? THANKS FOR ANY HELP |
Re: Loss of Plug-In authorization keys may occur
NTFS
It's the recommended format type to work with pro tools on pc's. The problem doesn't lie there, the problem lies that the overall name length of your file path is too long and may cause problem. |
Thanks.
My external hard drive has a long name. Once I unpluged the drive and launched PT10, then no problem. The puzzle is that this external hard drive did not create such problem before. Well, as long as it works, then fine. I can't solve many PT puzzles anyway. |
Loss of Plug-In authorization key Warning... Can anyone assist? | scitels | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-04-2021 03:07 PM |
Loss of plug in authorization key warning | geejo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-10-2016 12:35 PM |
Loss of Plug-In authorization keys may occur error | bubbasmodels05 | Pro Tools M-Powered (Win) | 6 | 10-04-2009 09:20 PM |
"WARNING Loss of Plug-In authorization keys may occur" | tunecrab | Pro Tools M-Powered (Win) | 2 | 05-09-2007 01:29 PM |
Authorization keys | Tonemonkey | Digidesign Hardware & Software | 1 | 06-25-1999 10:18 AM |
