Avid @ NAMM 2018
Old 09-18-2012, 11:49 AM
Ezrag Ezrag is offline
Default Oxygen 8 with Pro Tools 10? Help?
Recently upgraded to PT 10. Trying to use my Oxygen 8 MIDI keyboard to control plug ins (Vacuum), and it's not working, no matter what. Works fine in Ableton, Garage Band, so I know it's not a Mac OS issue, it's something in Pro Tools.
I am using Mac OSX, 10.7.4, with the Digi 002 Rack.
I can affect it using the mouse, but it just won't recognize anything from the keyboard.
I've got M-Audio keyboard selected in MIDI Controllers, I've got all the options checked that normally worked before (in PT 8).
Searched the web for drivers for the Oxygen 8, but it seems I shouldn't need any.
Does anyone know what the problem is? Hoping the answer is anything other than "you need to spend more money on another upgrade..."
thanks!
Old 01-10-2013, 05:31 PM
gabel gabel is offline
Default Re: Oxygen 8 with Pro Tools 10? Help?
Having the same issue. Did you solve it? Appreciate it..
Old 01-13-2013, 03:36 PM
thanks!
On Mac you have to configure things inside audio/midi setup in OSX. If you don't do that things won't work. Also make sure the Oxygen is set to work via USB and not the traditional MIDI ports - it can only work on one at a time, not both.
Jack
QAPLA!
m audio oxygen 61 in pro tools 10.3.3 201spotlite MIDI 0 03-02-2013 06:41 AM
oxygen 49 3gen and Pro Tools 9 tim.bassanello Pro Tools Software (Mac) 1 07-31-2011 09:22 AM
Oxygen 49 not working with Pro Tools LE 8 on 002 livingspacestudios MIDI 1 12-07-2009 02:57 PM
M-Audio Oxygen compaitable with Pro Tools LE? summersjon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-03-2008 11:02 AM
Oxygen 8 v2 and Pro Tools Pogodan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 07-10-2007 05:05 PM
